'89 Range Rover Winston-Salem, NC
I am the cruiser head in the family and my brother got into land rovers. He is trying to sell his truck so I figured I would post on here for him.
Here is everything:
FOR SALE
1989 Land Rover Range Rover Classic
“The Best 4x4xFAR”
$9,500
If you’re looking for a unique off-road vehicle that will absolutely go anywhere yet still can be driven as an everyday vehicle, here is your truck. This is a 1989 Land Rover Range Rover Classic. It has been meticulously built (as a go anywhere vehicle) for the past eleven years by my own bare hands and through every step of its formation has had the best service and upgrading a car could ask for. I have become a Land Rover enthusiast and learned this vehicle from top to bottom. I like Land Rovers so much I even bought another 1995 Range Rover Classic to play with as well. As I built this ORV I designed a vehicle that is not like any other and will stand out in a crowd no matter what. I installed the best of the best in service and parts on this vehicle. Words can’t even explain how many hours have gone into this vehicle to get it to the point that it is now. It has been my hobby and my pride and joy and I hate to see it go. However, whoever decides to take this vehicle on will get the best looking well thought out Range Rover in the US.
Lift Kit Parts:
Steering Damper Relocator $70
Rovertym 5" springs $380
Rovertym front shock mounts $125
Rovertym rear spring cones $120
Rovertym rear a arm extension $150
Custom Rear Trailing links $300
Rovertym Rear shock mounts $155
Rovertym Front Radius Arms $250
4 Bilstein Remote Resevoir 7100 shocks $700
Rear Great Basin Rovers Double Cardon Driveshaft $400
Front Double Double Cardon Driveshaft $580
5 black 15" wheels $305
5 36" Super Swamper TSL radial $1,300
Rovertym Body Lift $215
Old Man Emu Steering Damper $75
Additional Accessories:
Surco Roof Rack w/ expanded metal floor $300
ARB Bull Bar $800
Dixon Bate recovery hooks $300
Warn 12000 lb winch $1,545
Roller Fairlead $100
Skid Plate (front) $280
Snorkel $365
Safari Gard Diff Guards $200
Hella 4000 rallye euro beams x 2 $300
Hella 500 rallye lights x 4 $150
2 fog lamps (rock lights) $40
Rear trailer hitch recovery hook $75
Alpine CD player $200
JBL speakers $75
Pioneer speakers $60
Land Rover Floor mats $100
Uniden CB Radio $100
Fiberglass antenna $35
Power inverter $60
Rear Tail light gaurds $130
Waterproof Seat Covers $190
Rear Cargo floor protector $120
Hi Lift Jack $70
Hi Lift Jack mounts $30
2 levo gauges $30
Custom Center Console $150
Viper Alarm System $280
Hella Light Switch Panel $60
Custom rear toolbox/subwoofer enclosure $unkown
Vision Plus Headlights $50
Upgraded parts (heavier duty than stock):
K&N Air Filter $45
Ironman Polyurethane bushings $200
Stainless steel braided brake lines $125
8 Bosch Platinum +4 plugs $60
8.5 mm Magnecore plug wires $125
Rear 24 spline axles and differentials $300
Front 24 spline axles and differentials $300
LT230 Transfer Case $500
Alternator mount kit $125
Alternator (150 Amp) $150
Optima Deep Cycle Battery $230
Total for only Accessories/Upgraded parts $13,475 (not including installation labor costs or shipping fees)
*******Vehicle Also comes with boxes full of spare parts**********
Recent Service Work (with all new parts): Total for services if performed at dealership $5000+
Headliner
Distributer Amplifier Module
Ignition Coil
Head Gasket
Machined Heads
Cooling system thermostat
Fuel Filter
Idle Air Bypass Valve
Fan and Viscous coupling
Wheel Bearings (all four corners)
Cooling System flushed
Air Conditioning system
Air Conditioning Thermostat
Heater Core
Radiator
Synthetic Fluid Change (diffs, trans, etc.)
Rear upper A-arm ball joint
Tie Rod ends
Belts
Rear wiper motor
For anyone who has dealt with automotive service centers, they know that when they take a part off to replace or diagnose a problem, the service crew does not take the time to clean internal or external components of parts. They fix only the part that was broken even it is means putting it back with other dirty parts around it. This was the reason I chose to install and service every part on this vehicle. From taking the engine apart to dismantling the dashboard to fix heater core, every part was cleaned and adjusted before refitting all components. So after each project the parts were at new condition when refitted to the vehicle.
This truck will go anywhere the heart desires. With a suspension system with 14” of travel, a large boulder is no match for this machine. The truck can cross nearly any obstacle. And even if an obstacle causes problems or the truck gets stuck, NOTHING is a match for the 12,000 lb winch. Four wheeling at night is not a problem at all either. With 4 sets of lights facing in every direction and the roof rack pre-wired for more lights, this truck lights up like a landing strip in the night. People can see you coming for miles. If a camping trip is your desire, just load up the truck and go. You can take it as far off of the normal path where no one is within miles. And even while you are that far away from civilization, the truck has a built in 350 watt power inverter. It can power a TV, microwave, spot lights, blender etc. just like a normal house outlet. This even comes in handy for concerts where tailgating is a must.
This is not a vehicle for everyone. I will use judgment when selling this vehicle to its new owner. I have put so much blood, sweat, and tears that I will make sure the new owner will take the same care of it.
I am pricing this vehicle to sell. At a price of $9,500 this vehicle will not be around for long. This description only says about a ¼ of the information that really needs to be explained about this truck. Please feel free to call me with any questions or for further information.
Thanks,
Ryan Wilcox
(336) 669-5991 mobile
rwilcox@sealingagents.com
more pics
here are some more pictures
Back to the top for a price drop.
$8500
