So replaced idle up VSV for AC. Was very please when all worked like it was suppose to until..... I head a faint whistling sound like a bad vacuum leak, then a very nice POP!!! and tons of vapor and oil blowing out of front driverside grill area. So looks like a seal blew going to or from receiver. Grrrr now back to no A/C.
So a little research and I'm looking at swapping out H/L ports to 134a style. Replacing seals through out system minus compressor. Draining oil from compressor. Replacing receiver. evacuating system, vacuum testing it. Replacing oil and recharging with 134a.
I found this tech bulletin http://www.toyotapart.com/1986-1994_86-94_R-12_AIR_CONDITIONER_SYSTEM_RETROFIT_T-AC98-002.pdf
I'm hoping o'rielly, autozone, or advance have the manifold guage set and can evacuate plus vacuum test. Otherwise I'll just buy a set from HF, unless someone in area can help me out.
I've never worked on the AC system. Am I missing anything??
