After much searching, reading and little if any finding, I'm hoping for some help here in the HC forum.
I have a pair of Biondio Racing electric line locks from Summit. My plan is to use them on steep inclines where I have stopped and need to get going again without slipping back. I'm not talented enough to use one foot on the brake and gas or brake and clutch at the same time. I still have my OEM parking brake, so the line locks will NOT be used as a parking brake. And lets not get into the legality of line locks again, please.
So I need to plumb the two line locks and maintain the proportioning valve for the rear disk brakes. This is where any direction including pics and details on parts used would be very helpful. There's not a lot of room near the master cylinder so space management is an issue.
Here is what I plan so far:
10mm x 3/16 brake line out of master to -
SuageLock type compression fitting (3/16 brake line to 1/8 NPT male) to -
Biondio line Lock (1/8NPT female inlet and outlet) to -
SuageLock type compression fitting (1/8 NPT male to 3/16 brake line) to -
1) 10mm fitting 3/16 brake line to front brakes - or
2) current adapters to summit proportioning valve to rear brakes
I have a cheap Harbor Freight tubing bender that I've used in the past to bend a short section of brake line from the master to the proportioning valve.
Also have a few sections of 10mm x 3/16 straight brake line from Advance Auto. Ask for the 3/16 brake line with Japanese fittings (10mm wrench). Lengths vary.
Thanks in advance...
