Go Back   IH8MUD.com > General Tech Forums > Electronic Toys
Old 02-10-08, 08:41 PM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
AppleTech's Avatar
Product Review: CB-AM/FM Antenna Splitter (Firestik AR-1A Match-Maker)
I purchased this device because I wanted to use my CB antenna as my AM/FM antenna so I didn't have to have 2 antennas on my truck. I installed it on Saturday and I've been trying it out for the past 2 days.
Info:
walcottcb.com
AR-1A
Basically what this unit does is split your CB antenna signal into a dual-cable that hooks into the CB and stereo head unit for AM/FM signals.
CB Antenna -> Match-Maker AR-1A -> CB Radio/Stereo head unit
Installation:
Installing the unit was simple enough, and the instructions were very easy to understand. You disconnect the antenna coax from the radio and plug it into the Match-Maker, then you plug the coax cable from the Match-Maker into the CB radio and plug the standard antenna cable into the back of the AM/FM stereo head unit.
I should note a few things about tuning:
- Your SWR should be properly set for your antenna/radio setup BEFORE you even start hooking the Match-Maker up. For more info on tuning your CB radio/antenna, see Firestik's tech help section: Setting the SWR of Your Antenna© - Firestik® Antenna Company
- Once you hook up the system, put an SWR meter in between the Match-Maker and the CB radio. Using the built-in tuning screw, you must tune the Match-Maker so that the SWR is below 2.0 on CB channels 1, 19, and 40. Make sure you remove the screwdriver from the Match-Maker when measuring SWR or it can throw off the reading. Make adjustments in no more than a half-turn at a time, as it is very sensitive.
These steps are very important because when I first hooked it up the SWR was in the red on all channels because the Match-Maker hadn't been tuned to match my setup.
Performance:
I don't use AM, so I haven't tested that, but FM seems to be very clear but the range seems to be decreased. I can't catch as many stations as I could before, but what stations do come in are much clearer. However, there is occasional static "blips" but they are not very noticeable. The one reason I think that I might not be able to catch as many stations is because I only have a 3' Firestik and it is mounted fairly low, so it does not stick up above the roof of my truck. Therefore, if you have a whip or taller antenna, you will probably get much better reception.
The CB TX/RX range does not seem to be affected and I hear no interference from using both devices (CB and radio) at once.
Overall:
I am satisfied with this unit but if you listen to the radio very often and you listen to a wide variety of stations, make sure you install this unit within your first 30 days of return policy to you can make sure it works for you. Otherwise, it is a great solution for someone like me, who only listens to the radio occasionally and didn't want to have 2 antennas on my truck
1996 FZJ80 - OEM Locked, BFG M/T KM 285/70-17 on OEM FJC Wheels, IPOR Skid Plate, CDL switch/Pin-7 Mod, York OBA System, Scangauge II, Cobra 18WX STII/Firestik II 3'
1975 Volvo 244 GL
1983 Volvo 244DL
1990 Volvo 745T
2006 Scion TC
AppleTech is offline   Reply With Quote
Old 02-10-08, 09:37 PM   #2 (permalink)
EricG's Avatar
Thanks for the writeup ... my power antenna needs replacing, and I've been thinking about just putting a CB antenna there and getting one of these.
It is neither necessary or possible to educate someone who never questions anything. - Josephe Heller, Catch 22
93 FZJ80 - 285s, 2" OME, CDL, 7pin, Locked Axle transplant, Redline front bumper & sliders.
EricG is offline   Reply With Quote
Old 02-13-08, 06:16 PM   #3 (permalink)
esh
esh's Avatar
TLCA# 4408
I have this mod and love it.
Ken, Cascade Cruisers
'64 FJ40, '66 FJ45, '79 FJ40, '81 BJ42, '82 BJ42, '85 xcab, '89 HZJ62
esh is offline   Reply With Quote
Old 02-14-08, 12:09 PM   #4 (permalink)
EricG's Avatar
Where did you get this unit? Reccomended vendors?
Old 02-14-08, 01:08 PM   #5 (permalink)
esh
esh's Avatar
TLCA# 4408
They're only about $20, really anywhere that sells Firestick should work.
Old 02-14-08, 11:30 PM   #6 (permalink)
AppleTech's Avatar
I got it from walcottcb.com - very reputable and I haven't had any problems with them.
1975 Volvo 244 GL
1983 Volvo 244DL
1990 Volvo 745T
2006 Scion TC
Old 02-14-08, 11:31 PM   #7 (permalink)
AppleTech's Avatar
If you don't mind my asking... what type/size of antenna do you have? Upon further use I'm noticing that my FM band is really pretty week (I'm only running a 3' Firestik). Do you have any tips on tuning it?
1975 Volvo 244 GL
1983 Volvo 244DL
1990 Volvo 745T
2006 Scion TC
Old 03-18-08, 05:21 PM   #8 (permalink)
EricG's Avatar
Anything further on this? How bad is your FM with a 3' firestik ... I know that's hard to quantify.
Old 03-19-08, 12:05 AM   #9 (permalink)
AppleTech's Avatar
It only really becomes an issue when you are getting out of range of the station - it has less reach than the stock antenna.
-Phil
1975 Volvo 244 GL
1983 Volvo 244DL
1990 Volvo 745T
2006 Scion TC
Old 03-19-08, 03:00 PM   #10 (permalink)
EricG's Avatar
-Phil
I'm guessing it has better reach then the 1/4" broken off stub I've been putting up with on my honda for 6 months, so I should be ok
Old 04-01-08, 04:43 PM   #11 (permalink)
forestdan7's Avatar
TLCA# 17532
I was going to post a thread about this, but then I ran across this one.
Just installed this splitter, and my FM is coming in better (I had a 1' rubber whip on the fender beforehand), and the CB SWR numbers have dropped considerably after tuning.
I'd recommend this, especially since it's so cheap. I'm running a 4' Firestik-type antenna on the front bumper, and nothing on the fender. I like the look with only one antenna.
I also tuned the AM, and it's working fine, too. I don't use AM that much, though.
1985 FJ60
1987 4Runner -- SOLD
2002 4Runner Limited
2007 Honda XR650L
forestdan7 is offline   Reply With Quote
Old 05-31-08, 02:15 AM   #12 (permalink)
NLXTACY's Avatar
TLCA# 19015
I am about to order the 3' Firestik but I noticed some options, for the complete CB newb, which of the firestiks do you recommend AND how to mount them on an externally stock truck? I have seen some cool mounts that fit between the hood and the fender but no idea what was used. Back bumper is ok too if I knew what other 80 owners used.
ふざけんなよ!
Old 06-01-08, 12:44 AM   #13 (permalink)
AppleTech's Avatar
Here is WalcottCB's page with a list of hood-channel mounts:
WalcottCB.com: Hood/Fender/Door Groove -
The Firestik II with the tunable tip is fantastic. I love my 3' one - has plenty of reach and fits in my garage (it's mounted on my front bumper:
Make sure whatever you order that you get a spring and a good Coax cable - this is imperative for a good setup. I just buy the Firestik kit as it comes with great directions... This kit may actually work for you - includes the hood groove mount and coax - just add a spring to your order as well and you should be all set to go. I don't know if this hood mount would fit our trucks but I've seen a similar one used.
Firestik MK174 - Hood Groove Mini Kit
Also, DO NOT USE YOUR RADIO UNTIL YOU HAVE TUNED IT! You can damage the radio! PM me if you wanna work out a time that you can stop by my place and we can tune your antenna (EDIT - I know this sounds gross... but I should have clarified and said your "CB" antenna lol) - I've got an SWR meter and we can get it all set up for you. Set it and forget it!
-Phil
1975 Volvo 244 GL
1983 Volvo 244DL
1990 Volvo 745T
2006 Scion TC
Old 06-02-08, 01:12 AM   #14 (permalink)
NLXTACY's Avatar
TLCA# 19015
Phil you rock!
As soon as I get this ordered and in my hot little hands I'll let you know.
Joey
ふざけんなよ!
Old 07-04-09, 05:58 PM   #15 (permalink)
Rum Runnin'
GLTHFJ60's Avatar
TLCA# 17825
Garage
Bringing this up to the top because I used this thread to do my CB install.
So I set up my CB today and tuned it, got it to a SWR of 1.9 on all channels ( have some more tweaking to do ). Either way, I wanted to hook up my Matchmaker, which I know needs to be tuned as well, but when I hooked it up, my SWR meter was pegged in the red zone, indicating a short in the system. I unhooked it and tested the antenna + cb alone again, and it still read 1.9 on all channels.
I'm thinking that the AR-1A must be faulty because I only read a short in the system when it's hooked up. Does that sound right? Should I go order a new AR-1A?
Johnny C
Waiting to be installed:
Previous Rig:
1987 FJ60 - Big Red
ΦΚΤ - Fall 06
GLTHFJ60 is offline   Reply With Quote
Old 07-04-09, 08:17 PM   #16 (permalink)
AppleTech's Avatar
To be honest with you I pulled the Matchmaker out of my system a couple months ago. I was getting reports from others that my voice quality was bad and it sounded like I was over-modulating (I don't have GAIN on my radio and my SWRs were really high). I pulled the MatchMaker after being unable to properly tune it with it installed and I'm just running with my stock antenna now :(
-Phil
1975 Volvo 244 GL
1983 Volvo 244DL
1990 Volvo 745T
2006 Scion TC
Old 07-04-09, 11:12 PM   #17 (permalink)
Rum Runnin'
GLTHFJ60's Avatar
TLCA# 17825
Garage
-Phil
Well that's not the answer I wanted.
kevinmrowland has been running one for a couple of years now with no problems and great reception, so I have faith in the unit. I want to try it either way because I really don't want to run 2 antennas. I wanted to know if you guys thought if my particular unit was broken.
Johnny C
Previous Rig:
1987 FJ60 - Big Red
ΦΚΤ - Fall 06
Old 10-26-09, 08:14 PM   #18 (permalink)
JLH911's Avatar
TLCA# 18753
I'm having a problem with this splitter. I know a lot of people don't listen to AM radio, but I do and you'd think you'd get decent reception with a 3' firestik antenna. I followed the instructions and I'm getting really bad reception.
I did check to make sure there is no short with the antenna per the Firstik instructions and diagram.
I did clean all the ground connections so I know it's not that. Using the same ground connections that I used with my o.e. antenna and I never had issues with it.
Any thoughts?
87 FJ60 Stock...for now
JLH911 is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/electronic-toys/204526-product-review-cb-am-fm-antenna-splitter-firestik-ar-1a-match-maker.html
Posted By For Type Date
Let's see your CB radio and antennas mounted. - Tacoma World Forums This thread Refback 09-30-09 02:35 PM
One antenna CB/FM/AM - Tacoma World Forums This thread Refback 05-26-09 06:34 AM
