09-19-07, 06:10 PM
Lifer with a 2F-ETI
Home Brew Intercooler
This is posted in the 40's section but I though I would re-post it here too as it may be of more use.
If the wife's not complaining your not spending enought time with your 40!
2F+3FE+T+I-3F=2F-ETI
THE MULE Est @ +400hp @ 15PSI
DYNO'd at 8PSI 181kw/244hp & 560Nm/413ftlb @ the RW 8th Dec 08
EST @ FLY 283KW/379HP
Links
Mac's Space
On the rev limiter
Advanced (HB) Intercoolers
09-19-07, 10:31 PM
Some nice work there.
09-20-07, 12:38 AM
Very nice handiwork there.
When you get it done, have you got enough instrumentation to work out how much heat it's pulling out?
09-20-07, 01:54 AM
Lifer with a 2F-ETI
The Wolf V500 can and will monitor the air temp after the intercooler in the plenium , I have access too a laser temp sensor too. Though I am tempted to get an air temp sensor on the input just to see if this home brew kit works and if so how well the ECU can handle it no problem.
Some numbers would be interesting for sure.
Just have to figure out what radiator and thermo fan to use along with an electric pump.
Links
Mac's Space
On the rev limiter
09-20-07, 03:56 AM
Since you're in Aussie, the subaru air/water intercooler pumps shouldn't be too hard to find. I've got one and they are ideal, pull about 5 amps at full load.
I'm using a cabin heater radiator. It does the job, find one from a bus cabin heater if you feel the need for something bigger.
09-20-07, 01:49 PM
Turbo Diesel Lover
Intercoolers @ 14PSI can drop ( properly suited ) about 50ºC - 60ºC at HW speed ( talking about air to air ) how much you expect on you . ?
BTW it's a nice job !
HJ-60 2H-T Intercooled Tencha
Originally Posted by crushers
09-20-07, 02:38 PM
Lifer with a 2F-ETI
I have no idea, the math that goes into calcultaing these thing is way over my head
One thing I do know is at comp highway speeds are never achived, I was quoted $3000Aus buy a company here in Melbourne that use these cores, for a custom made intercooler using 3 cores (they said that would be sufficient to my needs). I bought 4 on ebay and what the hell used all of them  for $50Aus
So making a home brew intercooler with little understanding of heat transfer rates and the math that goes into them is a bit of a punt.
On the other side of the coin if it works it will have been very rewarding to do it myself and save a fortune.
Proof for me will be in the pudding
Links
Mac's Space
On the rev limiter
09-20-07, 03:14 PM
Turbo Diesel Lover
And I thought gent a nice deal with mine ..
09-20-07, 04:04 PM
Lifer with a 2F-ETI
I have emailed the R&D department at Laminova with a link to the thread for their comment, they may or may not care to comment but you can always ask the experts.
Hi Mattias,
I was wondering if you would care to comment on my use of your Laminova intercooler cores. You may even find it of interest. Any suggestion of how well this will or will not work will be more than welcome.
http://forum.ih8mud.com/showthread.p...light=laminova
Thankyou for taking the time if you do so.
Regards Matt McInnes
Links
Mac's Space
On the rev limiter
09-20-07, 10:12 PM
#10 (permalink)
fawk yeah! Do you just run the engine coolant lines or do you need another reservoir? How does that work?
PORTLANDERS + NW CRUISERS::
$@#!! L A N D C R U I S E R S P E C I A L T I E S !!!
H O R R I B L E W O R K , W O R S E A C C O U N T A B I L I T Y!!!
09-20-07, 10:19 PM
#11 (permalink)
very very technical and nice mechanical job, and very interesting for me, in italy water intercooler are not used yet.
09-21-07, 09:31 AM
#12 (permalink)
Turbo Diesel Lover
Thanks .. !
09-22-07, 07:14 AM
#13 (permalink)
Urban Offroader
so basically you have a seperate cooling system from the charge air cooler? With a small radiator in front of the main radiator? I am intrested to see the temp drop, pre and post intercooler. How did you cut your metal so good? Post some pics of the tools you used.
good work!
1991 T4R 5sp.
1988 FJ62
1999 Jeep Wrangler
I want an FZJ80 with minimal mall cruiser stuff, and F+R diff locks. Can trade jeep+cash, or just cash. Prefer OBD1.
Please i despertly need to get my 1FZ fix.
Never mind, I got an RX7 to play with this summer.
09-24-07, 04:30 AM
#14 (permalink)
Lifer with a 2F-ETI
good work!
Used a lath and a milling machine to make the parts, but it could be done with more basic tools and ingenuity. Eg hole saw
Small radiator and thermo fan will be used as I want this to work at low speeds and an electric pump. May even be mounted in the rear out of the way of the mud.
Links
Mac's Space
On the rev limiter
09-24-07, 01:05 PM
#15 (permalink)
Lifer with a 2F-ETI
Thanks .. !
No Problem
Links
Mac's Space
On the rev limiter
09-24-07, 06:58 PM
#16 (permalink)
80L/min!
That's a whole lot of water. I guess that rules out the subaru pump. Maybe the Davies one?
09-24-07, 07:36 PM
#17 (permalink)
Lifer with a 2F-ETI
Yep I was looking at the 110 model should give plenty for my needs.
Links
Mac's Space
On the rev limiter
09-24-07, 08:22 PM
#18 (permalink)
How about the little bosch water pump?
Really interesting thread, great looking work.
Come and visit us in Duncan, Vancouver Island, BC
www.raddcruisers.ca
Monday - Friday 08:00 - 17:00
09-24-07, 10:23 PM
#19 (permalink)
Lifer with a 2F-ETI
You have a link or part number?
Links
Mac's Space
On the rev limiter
09-25-07, 09:03 AM
#20 (permalink)
http://images.google.ca/imgres?imgur...%3Den%26sa%3DN
One of the reasons I like bosch also is they offer a 24volt pump.
What do you think the weight is going to be including coolant?
Not sure if this will work, never added a link before.
www.raddcruisers.ca
09-25-07, 09:42 AM
#21 (permalink)
Lifer with a 2F-ETI
Thanks for the link works fine, I have a few friends that work at Bocsh so I maybe able to get it much cheaper if it's available.
Final weight I have no idea but once finished I can weigh it up, though weight is not a great issue over sturdy construction for competition.
Links
Mac's Space
On the rev limiter
09-26-07, 06:02 PM
#22 (permalink)
Lifer with a 2F-ETI
Dropped the sleeves, end plates and divider in to the welders today. Cash job  The guy that does the welding is top notch with a tig. But as a job on the side I have to be patient, 2 weeks.
While this is done all the end caps can be machined up, once we get the newly welded up section back the holes to mount the end caps can then be drilled in the end plates before the final outer skin os welded over.
Links
Mac's Space
On the rev limiter
09-28-07, 03:03 AM
#23 (permalink)
i have a hzj75 ute and i am going to mount my cooler core in the centre of the bullbar, horizontally. open the flat bit and put mesh above core or maybe flute the top of the bar to direct air in, thermo also underneath...out of harms way
10-06-07, 12:03 AM
#24 (permalink)
Lifer with a 2F-ETI
All welded up thanks to Awill4x4 and as always top quality work.
Now on with the end caps
Links
Mac's Space
On the rev limiter
10-24-07, 07:00 PM
#25 (permalink)
Lifer with a 2F-ETI
End caps are complete
3/4 assembled
Pressure tested and all good
Next the outer skin is to be welded on, along with the inlet and outlet.
Links
Mac's Space
On the rev limiter
10-31-07, 03:54 PM
#26 (permalink)
Lifer with a 2F-ETI
Links
Mac's Space
On the rev limiter
10-31-07, 04:05 PM
#27 (permalink)
pretty damn cool if you ask me...
thanks for posting...
11-01-07, 11:25 PM
#28 (permalink)
Lifer with a 2F-ETI
Will be dropping it at the welders next Wednesday morning
Links
Mac's Space
On the rev limiter
11-02-07, 01:41 AM
#29 (permalink)
looking forward to the fitment...
cheers
11-09-07, 08:30 PM
#30 (permalink)
Lifer with a 2F-ETI
Links
Mac's Space
On the rev limiter
LinkBack to this Thread: http://forum.ih8mud.com/diesel-tech-24-volts-systems/178335-home-brew-intercooler.html
| Posted By |
For |
Type |
Date |
| inside intercooler - Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips. |
This thread |
Refback |
04-19-09 06:23 PM |
| Saturn Ion Cooling System, Saturn Intermittent Wipers Stop, Saturn Ion Mpg - Demonmax |
This thread |
Refback |
03-08-09 04:14 AM |
| Laminova water to air intercooler - Page 3 - Patrol 4x4 - Nissan Patrol Forum |
This thread |
Refback |
02-21-09 06:05 PM |
This thread |
Refback |
02-15-09 01:51 AM |
| most hp out of the 4bd - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-29-08 09:41 PM |
| Water to air intercooler - Miller Welding Discussion Forums |
This thread |
Refback |
11-27-08 11:01 PM |
| fj40-2f-eti-locked-n-loaded.com Blog Archive I see the light |
This thread |
Refback |
10-26-08 07:36 AM |
| Outer Limits 4x4 Board :: View topic - Intercooler |
This thread |
Refback |
10-01-08 12:03 PM |
| has anyone considered - Page 9 - Saturn ION RedLine Forums |
This thread |
Refback |
08-28-08 09:03 AM |
| Outer Limits 4x4 Board :: View topic - 3B Middy with PWR water to air intercooler set up |
Post #0 |
Refback |
06-28-08 03:01 AM |
Post #0 |
Refback |
06-28-08 01:44 AM |
Post #0 |
Refback |
06-28-08 12:36 AM |
Post #0 |
Refback |
06-28-08 12:28 AM |
Post #0 |
Refback |
06-27-08 11:46 PM |
This thread |
Refback |
06-25-08 02:26 AM |
This thread |
Refback |
06-20-08 08:17 AM |
This thread |
Refback |
06-18-08 04:20 AM |
This thread |
Refback |
06-17-08 09:09 PM |
This thread |
Refback |
06-17-08 07:42 PM |
This thread |
Refback |
06-17-08 05:19 PM |
This thread |
Refback |
06-17-08 05:12 PM |
| My version of a top mount TD42 intercooler. - Page 2 - Patrol 4x4 - Nissan Patrol Forum |
This thread |
Refback |
05-22-08 08:49 PM |
This thread |
Refback |
05-22-08 06:10 AM |
This thread |
Refback |
05-22-08 05:53 AM |
| has anyone considered - Page 8 - Saturn ION RedLine Forums |
This thread |
Refback |
05-08-08 11:23 AM |
