Thanks to all that replied to my original thread regarding two FJ80s I was looking at to purchase. I did purchase the 1994. 231K miles. Loaded with lockers too. Never been off road. Many repairs/mods upcoming. This is a great site! Many thanks in advance for all the help I'm going to need.
EDIT 7/19/13: I have created threads and or postings in other areas where appropriate. Here are the links:
CUSTOMIZED KAYMAR REAR BUMPER
https://forum.ih8mud.com/expedition-builds/693488-customized-kaymar-dual-swing-out-rear-bumper.html
HOW TO - ROOF MOUNTED WIRING - LIGHTING/ANTENNAS
https://forum.ih8mud.com/expedition-builds/677159-how-wiring-roof-mounted-lighting.html
CUSTOM LICENSE PLATE MOUNT
https://forum.ih8mud.com/80-series-tech/697049-license-plate-blocked-spare-swing-out.html
EDIT 1/20/13:
I'm going to put my 'lists' here at the beginning of this thread to help keep track of everything. I'll update as needed. LAST UPDATE 7/19/13
1994 TOYOTA LAND CRUISER - Elsie
TO DO
Steering play
Passenger power seat
Antenna
Rear door light switches
Cruise control intermittent
Recover seats?
Windshield chip
Drivers rear mud flap screw - flare damaged
Power windows-slow
Wheel center caps?
Steering shaft u-joint & rag joint
Passenger door locks/key
Check engine light
Hood alignment
Add rear cargo dome light
OEM roof rack mounting - leak?
Front passenger door lock
Slow power windows
Gear shift handle
Switches on driver's door
Passenger running board damaged
Parking brake switch
n/a - Front passenger flare damaged (Bought replacement flares for all 4 corners)
Muffler/exhaust system
Wiring for roof mounted accessories - 12V and antennas
AWAITING INSTALL
Front facing camera - Installed not wired
Rear facing camera - Installed not wired
Pocket flares
Headlight washing system
2nd battery system
Battery switch/isolator
Battery status indicator LEDs
3 x Rigid Industries flood lights (Custom RAM mounts)
Driving lights - Installed but not wired
Rigid Industries 40" combo LED light bar - Installed but not wired
TJM 9K Winch - Installed not wired
Radiator overflow bottle - overflow tube
Fuel filter
Exhaust gasket/hardware
Hand throttle
Window weather stripping
Cigarette lighter socket for RTT
Rear hatch emblem
Belts
Front axle seal kit
DONE
Paint roof rack - powdercoated
Replaced hood struts
Replaced rear hatch struts
Replaces driver's tail light housing
Interior lightbulb to LED conversion
Replaced oil fill cap grommet
Replaced battery box grommets
Replaced throttle cable
Replaced intake hose
Replaced steering column surround (clam shell)
Replaced missing rear door carpet moldings L&R
Replaced missing fan shroud
Installed TJM XJS 2.5" progressive lift kit
Rebuilt read diff lock indicator switch
Removed 3rd row seats
Replaced climate control lights /dash lights/shifter light
Removed aftermarket alarm
Installed DEPO headlight housings
Refurbished factory grill
Converted to H1/H4 headlight bulbs
Replaced license plate lights
Replaced drive indicator light in shift console
Repaired rear hatch latch
Replaced factory subwoofer
Replaced battery hold down
Replaced shifter lockout plug
Cleaned EGR filter
Replaced air filter
Changed engine oil
Changed transmission oil
Changed diff (F & R) oil
Changed power steering fluid
Greased birffs
Replaced spark plug wires
Replaced spark plugs
Replaced distributor cap & rotor
Replaced charcoal canister
Rebuilt power steering pump
Installed Sony MEX-BT4100P stereo
Installed trailer light adapter/harness
Installed A-pillar remote police light
Installed TJM T13 front bumper
Mounted Falken Rocky Mountain ATS tires 315/75-16
Designed/built/mounted custom roof rack
Installed TJM Boullia roof top tent
Installed TJM awning
Installed Lightforce 170 driving lights with yellow lenses
Installed Rigid Industries 40" combo LED light bar
Replaced front door brakes (L & R)
Turned front brake rotors and replace front brake pads
Replaced receiver/dryer
Cleaned evaporator
Replaced expansion valve
Recharged A/C system
Replaced PCV valve
Cleaned and greased (white lithium) sun roof assembly
Made spare tire winch tool (3/8" socket drive)
EDIT 1/20/13:
TO DO
Steering play
Antenna
Recover seats?
Windshield chip
Power windows-slow
Wheel center caps?
Check engine light
Hood alignment
Slow power windows
Gear shift handle
AWAITING INSTALL
Pocket flares
2nd battery system
Fuel filter
Hand throttle
Rear hatch emblem
Belts
Front axle seal kit
DONE
Cleaned EGR filter
Replaced air filter
Changed engine oil
Greased birffs
Cleaned evaporator
Replaced PCV valve
