Home Forum Gallery CruiserFAQ Tech Links Store
IH8MUD Forum
Go Back   IH8MUD Forum > Toyota Tech Forums > 80-Series Tech
Follow IH8MUD on Twitter Visit IH8MUD on Facebook
80-Series Tech Tech regarding the 80/81-series Land Cruiser, including the Lexus LX-450 -- FZJ80.com
LinkBack (8) Thread Tools Display Modes
Old 07-22-05, 12:00 PM   4 links from elsewhere to this Post. Click to view. #1
Rookie2's Avatar
Adding coolant temp gauge?
Ran a search on this, but many of the pics. etc appear to have been dumped from the threads. I'm looking to install a temp. gauage to more accurately monitor coolant temps. Looking for something reasonable.
Thanks for any help, suggestions and pics.
Rookie2
1997 LX-450, Basically stock.
Rookie2 is offline   Reply With Quote
Old 07-22-05, 12:28 PM   #2
Parts Geek, M1 Mechanic
cruiserdan's Avatar
I am doing this exact thing tomorrow. Ben at Slee had a 270 Degree sweep Isspro electric gauge that reads from 100 to 240. He sent me that and an Acura 2 gauge pod that I will modify to fit. I already have a boost gauge so I will have to off that single pod.
I will be mounting the sender in the upper water neck in the circular "boss" on the neck. I have a new neck that I will drill and tap and then break into the system to install it. Swapping the neck will require removal of the distributor and the upper alternator mount. Since I have to go in that deep I plan to pull the alternator and install a new brush pack in it at the same time. It is original and at 132,000 miles so I'm sure the brushes are getting short. Since I will be that close it is a no-brainer.
Original owner 93 FZJ80,locked,blown,water/methanol injected(like a WWII fighter aircraft),lifted,winched,snorkeled,slidered,Sleeed ,moneypit. Balanced on a pin head. 95 FZJ80 trail truck (hers), 94 FZJ80 320K with a knock. 2009 Dodge Challenger SRT8, 465 horse HEMI, 6 speed manual trans, cop-attracting-red. Kimberly Kamper and some Garands.
Sponsor 07-22-05, 01:02 PM
Sponsored Link
advertisement
Old 07-22-05, 01:02 PM   #3
You want to do what...?
e9999's Avatar
I have been toying with the idea of simply gluing a thermocouple with conductive epoxy to some suitable metal surface to avoid having to drill /tap/open etc. May still do that. But the OBD approach seems more appealing all the time (for those of us who don't drive antiques... ). The disadvantage of the latter is that you would not have a display in front of you all the time...
: '97: 90K, 3xlock, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar Tradesman full rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!).
: '03: 125K
DDs: Accord, Prius
: souped-up DR650
Old 07-22-05, 01:29 PM   #4
Cobra Jet's Avatar
Here's another way of tapping into your coolant to get the temp for a temp gauge:
Pick one of the radiator hoses (upper preferred), splice it, then insert a section metal pipe that is the same outer diameter as the inner diameter of the radiator hose. The pipe would be drilled & tapped already so that a temp sensor can be screwed into it. I have also seen some weld a "boss" to the pipe so that the temp sensor can be screwed into the boss on the pipe. Before inserting the temp sensor into the pipe, apply silicone or liquid teflon to the threads on the pipe (or temp sensor). Screw the sensor into the section of metal pipe. Reinsert the small section of metal pipe between the splice on the chosen radiator hose and use (2) clamps to secure the hose & pipe.
Sometimes doing the above is easier than tapping a thermostat housing, especially if it's quite a bit of work just to remove the thermostat housing (or trying to access some other area to tap into the cooling system).
The most accurate reading will be that of a temp sensor that makes contact with the coolant fluid, rather than one that is attached to exterior metal surfaces (or sandwhiched into a radiator's fins).
Maybe the above is helpful to some, but that method is used by many folks in racing (drag, auto crossing, road racing, etc) and does not cause any detrimental affects at all.
- Phil
1992 FJ80 163k SOLD
1994 Cobra coupe #0013, 2011 Genesis Coupe, 2011 Tucson GLS
Cobra Jet is offline   Reply With Quote
Old 07-22-05, 01:41 PM   #5
LandCruiserPhil's Avatar
Garage
I installed a W/T sending unit the same place Dan speaks of a year ago. Depending on how anal you are you dont need to remove anything. I used 2 cordless drills for the job (1 with the proper size bit, 1 with the tap) didnt even remove the radiator cap lost maybe 2 oz of coolant. Once you have everything together less then 1 minute to install the sensor. Drill, tap, and screw the sensor in = done.
"Knowledge without experience is just information"--Mark Twain
Copper State Cruisers #3
Click HERE if you want to become a CSC member
LandCruiserPhil is offline   Reply With Quote
Old 07-22-05, 01:42 PM   #6
cruiserdan's Avatar
How about the shavings Phil?
Old 07-22-05, 01:52 PM   #7
e9999's Avatar
true that gluing a sensor is not as accurate but if it's metal and not exposed to the fan air flow, should be fine, especially if you use special epoxy and insulate the sensor.
As far as the hose coupling approach, they sell these things.
: '03: 125K
DDs: Accord, Prius
: souped-up DR650
Old 07-22-05, 01:53 PM   #8
Garage
I felt that the combination of the grease on the bits and the coolant on the inside pushing out that nothing was left behind inside. And even if a few shavings found there way in what adverse affect could it have? I feel I'm pretty anal but this didn’t bother me at all.
Old 07-22-05, 01:55 PM   #9
cruiserdan's Avatar
Hmmm,
Well I'll look at that tomorrow. I do kinda want to put brushes in the alternator anyway So I'll just drink a beer and ponder it......
Old 07-22-05, 02:05 PM   #10
ThinkTank Waterboy
landtank's Avatar
If that neck is made of aluminum you shopuld use Isopropyl Alcohol to lubricate the tap and not grease or oil. The alcohol evaporates at a faster rate keeping the chips cooler which is where the issue with clogging the bit comes in.
Rick Bigelow
Groveland MA 01834
Find your LANDTANK items at AJIK Overland Exchange
Old 07-22-05, 02:14 PM   #11
Garage
Thats good to know Rick. Thanks for the tip I will use it next time.
Dan if you drink beer prior the chips wont bother you at all.
Old 07-22-05, 02:35 PM   #12
e9999's Avatar
corn chips and salsa are nicer than the regular potato chips, they don't bother me at all...
: '03: 125K
DDs: Accord, Prius
: souped-up DR650
Old 07-22-05, 02:38 PM   #13
clownmidget's Avatar
Garage
Dan, I tapped that boss for the coolant line to the turbo following LandCruiserPhil's method. I did add a shop vac with a small hose sucking up as much crap as it could directly where I was drilling/tapping as well. I used grease to "grab" any aluminum and methodically cleaned the tap several times during the process. The boss is thicker than I suspected, plenty of threads there. Even going slow it didn't take very long at all, maybe 15 mins. The good news is that once you've got it tapped for the coolant temp sender it'll be a piece of cake to just plumb in the line over to the "new turbo"
Special note to Dan - That Acura dual gauge pod takes some MAJOR surgery to fit right! I laughed and called Slee just to check what "a little trimming" meant in CO...
The dremel was priceless for this procedure. Good luck!
Mike R.
04/1995 FZJ-80
A man may be a fool and not know it, but not if he is married.
H. L. Mencken
clownmidget is offline   Reply With Quote
Old 07-22-05, 02:42 PM   #14
Cube Dweller's Avatar
Kerosene or Rapid Tap for aluminum is preferred for tapping and cutting Al. I've never heard of using alcohol.
I spent quite a bit of time in machine shops.
Learning about Cuba and having some food.
The Ultimate Thread Welcomes You. Namaste.
Cube Dweller is offline   Reply With Quote
Old 07-22-05, 02:45 PM   #15
Rookie2's Avatar
So yall recommend any sites that have some product options to look at. I went to Slee's site, but didn't see anything like this shown in his products section. The dual gauge A-pillar setups I recall seeing looked nice (not sure what should go in the other slot for a non-superchargered setup), but that setup seemed to get a little to pricey. I just want something that better informs me on engine temps, and don't want to drop 500 bills for that.
Rookie2
Old 07-22-05, 02:47 PM   #16
MH_Stevens's Avatar
e9999 has told us several times that a PDA with software connected to the OBDII port is the best route and after much research I belive him to be right. I'm asking him again here what software will do this job.
Cheers,
Mike Stevens, Knights Landing (on the Sacramento River), California
'97 FJZ80 "Collector's Edition" Black 185K miles
MH_Stevens is offline   Reply With Quote
Old 07-22-05, 02:59 PM   #17
flintknapper's Avatar
Dan, please take careful notes on how you modify the A pillar pod. I've been wanting to do this for quite some time now. The only pods I could find were singles. I know you can "stack" them but I'd rather modify a full length.
I'm going to use the "Defi-D" series temp. gauge but the one you have selected is excellent also.
What color is the pod? I can paint to match...but I'd have to locate a plastics/vinyl paint that was pretty close in color to the grey I have.
Please post back when you're done...I am very interested to do this also.
'97 Land Cruiser, Moonglow Pearl
Chocolate Lab (Kota), I miss you.
ΜOΛΩΝ ΛΑΒΕ (come and take them)
flintknapper is offline   Reply With Quote
Old 07-22-05, 03:05 PM   #18
Originally Posted by Rookie2
(not sure what should go in the other slot for a non-superchargered setup), Rookie2
VDO makes a "head temp." gauge for those interested. I'm going to put a water temp. and an hour meter in mine.
I'd like to keep track of engine hours vs. miles driven for purposes of maintenance.
Old 07-22-05, 03:58 PM   #19
e9999's Avatar
already answered that I think, and a quick googling will give you various options, just tried the other day myself.
The cheapest one I've seen is this BR-3 thing IIRC but that is probably only RS232. There are several PDA options out there too. I didn't look at those. Prices seem to range from $99 to $300 for reasonable looking combos.
Obviously, having a laptop in the cab is not the best way to keep an eye on the temp while driving, but the versatility of these packages is very tempting, can display and plot all sorts of numbers.
: '03: 125K
DDs: Accord, Prius
: souped-up DR650
Old 07-22-05, 04:29 PM
Sponsored Link
advertisement
Old 07-22-05, 04:29 PM   #20
rocker
semlin's Avatar
flintknapper, what is the single pod model you have?. I tried a couple of acrua pods and the local place and they were nowhere near fitting.
93 fzj80
94 fzj80
66 fj40L
m101cdn trailer
"I have the conch" Piggy
semlin is offline   Reply With Quote
Trackbacks are Off
Pingbacks are Off
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/53142-adding-coolant-temp-gauge.html
Posted By For Type Date
FZJ80 Aftermarket Temperature Gauge This thread Refback 06-01-11 12:12 AM
FZJ80 Aftermarket Temperature Gauge - Expedition Portal Forum This thread Refback 03-12-11 10:55 AM
Periodic Table This thread Trackback 02-03-11 03:51 PM
óðåä çà íàëÿãàíå íà ìàñëîòî - Club Alfa Romeo Bulgaria This thread Refback 10-25-10 02:37 PM
óðåä çà íàëÿãàíå íà ìàñëîòî - Club Alfa Romeo Bulgaria This thread Refback 10-22-10 08:13 AM
óðåä çà íàëÿãàíå íà ìàñëîòî - Club Alfa Romeo Bulgaria This thread Refback 10-22-10 07:37 AM
Toyota Landcruiser 100 Series ‘98-‘04 Temp Gauge Mod :: LandCruiserWiki.info This thread Pingback 11-18-09 02:30 AM
Toyota Landcruiser 100 Series ‘98-‘04 Temp Gauge Mod | Paul's esoteric meanderings This thread Pingback 04-05-09 11:00 PM
vBulletin® ©2000 - 2012, Jelsoft Enterprises Ltd.
©2000-2012 by IH8MUD.com - ALL RIGHTS RESERVED
