Within weeks of purchasing my 1997 Land Cruiser in May of 2008, I had larger tires installed. Immediately I knew that the gearing needed to be changed to something lower. Over the last nine months I've been collecting the parts needed to re-gear the differentials and service the axles.
So this month I had the time to get this done and a Land Cruiser expert that was available to re-gear the differentials to 4.88.
I spent more time reading posts here on Mud than I will have spent on the this project. Thanks to all that have contributed. The FAQ and posts have helped me very much
Here's the driver's side with spindle removed:
Here it is out of the truck. There is visible wear from a seal on the right side:
Re-Geared 4.88 Front diff installed:
Re-Geared 4.88 Rear diff installed:
This would have been impossible for me without the help of my little friend from Harbor Freight Tools:
Old trunnion bearing races removed:
New Marlin Crawler seals and trunnion bearing races installed.
This Bearing Race and Seal Driver Set made easy work of installing seals and bearing races.
So far, I've used up over 300 blue shop paper towels. This is a very messy greasy job.
Early tomorrow morning, I'll start the reassemble of the axles. So if all goes well I should be done tomorrow.
