hi all, i am in the process of replacing my alternator on my 1991 land cruiser. had to take the smog pump above the alternator off for access to remove the alternator. should lock tight be used for the mounting bolts on either or both the alternator and or smog pump, nothing is mentioned in the fsm on this issue. if so any recommendations on "strength of" or brand to use. also any torque specs or recommendations on how tight these mounting bolts should be.
thanks
, cliff
thanks
