I have a 1984 toy truck, I was running a 350 .60 over sbc last year and the front end held togather. Now going with a 400sbc. The motor builder says 600hp. How long will the front end hold up? Will longfields hold up? Will the rear hold up to?
Forever so long as you don't ever use the gas pedal... It's a loaded question. At the very least I'd pull the diffs and make sure they are set up nice and tight. If you've lost carrier bearing preload, then the ring is going to deflect and it's going to go "pop-crunch" when you step on it. They are tough differentials, but they were designed for 1/6th that power... The fact that they are even usable in that application is admirable.
Tires are what's gonna kill you...
And Jim's somewhat right. You don't, or shouldn't have Toyota transmission gear ratios anymore. So you don't have to lower gears b/c you've got a tranny and POWA that can handle that ratio.
600hp and a stock Toyota solid axle? Never heard of it...
At least go V6 chunk, Longfields and the strongest axle shaft you can buy...
But I swear, if I was doing all that I'd drop a Dana in there and forget all that... The sky's the limit with a 60 or 70...
Or if you've got the money, Volvo or Unimog axles...
I ran last year 35s, 38s with cut ground Hawgs in the back and I have a set of skinny tractors that I run on the back with the 38s on the front. Have a new set of 42s now that havent been run on this truck. All tire are Swamper TSLs. Looking like Longs or Dirty 30s
You can get away with a lot in mud... But once the surface gets harder you won't be getting away with anything...
if nothing else it will be an interesting test, and you will have more ground clearance than your 1 ton competion, and thats the name of the game in mud.
I thought a dirty 30 was a 30 pack of cheap beerWhat's a Dirty 30? And are you running in mud?
5.71's and $600 horses....I wanna see the aftermath. It'l look like gear teeth soup!
Go with the stock ratio, as more wheel speed will work better in the mud, and youll definately have the power to push through.
