LinkBack (3) Thread Tools Display Modes
Old 01-29-09, 08:47 PM   #31 (permalink)
looks good thanks for adding onto this post.
I may have ramped it a bit vs the square edge.
looks pretty heavy duty and home made... like the gravel drive also.
missouriman is offline   Reply With Quote
Old 01-29-09, 09:05 PM   #32 (permalink)
Tartu hetkeen
liljlandon's Avatar
Garage
yeah, we had a buggy, cruiser and heep in the garage that day, so i was half in half out.
as for safety, those comfy foam puzzlemaster pads tend to catch fire, and they stick to what ever bodypart they touch when they are on fire too... Ask me how i know
Crusified:
You don't "lock" a Toyota's hubs, you "Call down the Demons".
liljlandon is offline   Reply With Quote
Old 02-03-09, 03:31 AM   #33 (permalink)
tlcruiser66's Avatar
Great write-up there missouriman, thanks for sharing.
I've done just about the same thing on my 85 4runner but have to finish up the front bump stops, how long did you make yours and how far back did you set them from the original location?
1966 FJ-40 Under Construction.
1985 4Runner. Something to play with while the 40s out for mods.
2003 GMC Sierra Quad-cab. Duramax diesel w/ all the toys. Diablosport Predator tuner and 33" tires.
tlcruiser66 is offline   Reply With Quote
Old 02-20-09, 03:01 PM   #34 (permalink)
with the lift, moving the front axle forward 3.5 inchs and the fact that the axle moves back ward under compression they ended up in the same spot.
I put on a 3.5 inch lift. the hydro assist cylinder hit the oil pan pretty hard. so I lowered the bump stop 2.75 inches.. 3 when you include the 1/4 inch plate on the end of it.
this is on our two current trucks. yep, two of them, dual cased, stock front and 4.7 rear with twin shift in the rear and 5.29 gears. locked front and rear. longs. longs lock out gears. 36 inch sx tires.
bud built transfer case mounts, chained the motor mounts,
lot rather lift a tire then poke a hole in the oil pan.
doing cages for the toys right now.
Old 04-08-09, 10:48 PM   #35 (permalink)
Rookie
Do you have more info on the front bumper? I dont like tube bumpers! I like how close yours sit!
yotachad is offline   Reply With Quote
Old 04-12-09, 08:56 PM   #36 (permalink)
Dedtruk's Avatar
TLCA# 1091
Great thread Missouriman! Thanks! Dimensions, how you built/plans on that front bumper? Love to copy it if you don't mind the sincerest form of flattery ...
'85 PU, 4.88s, ARB front, Detroit rear, 4.7 single case (for now), Budbuilt, 33" Swamps, 63" Chev rear springs
'74 FJ40 flogged nag
'76 FJ40 stocker resto candidate
'78 FJ40 destiny unknown
'81 FJ40 rebuild under way
Dedtruk is offline   Reply With Quote
Old 04-13-09, 09:29 PM   #37 (permalink)
I will have to dig around for the tablet that I wrote every thing down on.
no real plans. just started in with the idea.
winch box mount I had bent out of 1/4 inch steel.
braces 1/4 inch
(wings, outer part of bumper) 3/16.
up rights 1/4 inch
the bar above the winch is a bolt in, so you can get the winch out.
the other bars are dom, that I chose for size. middle is same as the bolt in.
the next is slightly smaller and like 1/4 inch thick!!
the outer is I think 1 or 1 1/4 inch od and also like 3/16 inch thick.
way over kill but I really think they made the bumpers a lot stronger. my wife has twisted hers pretty good and it popped right back into shape.
here are some more pictures.
remove grill.
weld a brace across the radiator lower cross brace and remove the stock one.
I cut the stock bumper front frame mounts right at the upper bumper hole.
welded a 1/4 plate that I cut from frame rail to frame rail.
set the winch plate box on the cut stock mounts and tack welded it on.
then built out from there.
I got the angle cut by holding the long piece of steel up and using a 1.5 inch wide strip against the winch mount box. and marked how much to cut off the back side.
hope that makes sense.
here you can see that I welded a old electric fence post across to replace the stock brace.
hole for moving the steering box way forward
frame brace and stock mounts
forming the ends, I also welded a plate on the outer edge of this, then heated it with a torch and beat it into the shape that I wanted.
I used tri angle 1/4 inch steel and braces to replace the stock ones!!!! it was just easy to use the stock mounts while mocking every thing up.
here you can see the mounts. and braces.
three tri angles to the 1/4 frame to frame brace and a center side to side brace up under the winch mount box.
steering box moved forward and up.
How to save your self from having to buy longer soft brake lines.
i thought this was a good money saver!! and uses stock lines.
Old 04-13-09, 11:59 PM   #38 (permalink)
TLCA# 18962
Awsome thread!
I vote sticky.
Mine:
1989 maroon single cab short bed, 2 inch lift, 32" a/t's, locked front and rear.
For my :
1996 black 4Runner, factory bullbar, pink lay on the mirror.
cavemancaleb is offline   Reply With Quote
Old 04-14-09, 10:27 AM   #39 (permalink)
my original write up.
removing 85 transfer interlock pin for twin shift
you can get it out pretty easy, ask questions if you do not under stand what I am saying.
if you are going to 4.7 gears, you will all ready have it this far apart. so this will not do you much good, but if you are using the stock gearing this will save you 3 or so hours.
to start, you have just the case out, that is one case not bolted up as duals.
take the shifter out.
take a good parts magnet the ones that are on the extension rod.
now pull that (drivers side) shift rail forward with a screw driver. you may have to shift the other rail to do this.
Mark it at the edge of the case if you are cutting the rail for dual cases. use tape.
now stuff, just a bit, not to much of a paper towel or rag down and around to help the magnet catch the roll pin. remember you have to get the rag back out, so don't get carried away.
I think that it is a 3/16 punch that I used.
Also this is the shift rail that you have to some times cut flush with the case, in the forward position for dual cases. (drivers side.) a dremel tool with the cut off wheel is what i used.
remove the 6mm shift rail spring bolt. remove the spring, make sure you get the little ball also.
now knock out the roll pin and pray to the Toyota gods that the magnet catches it. mine did.
now make sure you mark the shaft or look close at how it went in.. don't rotate it.
pull it part way out. don't pull it out of the shift fork.
cut it off where you marked it.
I used paper towels to hold the shift fork and rail forward and my magnet that caught the roll pin. I then tipped the transfer case on it's side to dump out the inter lock pin. it is pill shaped and about 3/4 inch long.
now slide the shift rail back in.. make sure that you have the roll pin hole lined up.
beat the roll pin back in. I used a needle nosed vice grip so I would not loose it into the case.
took several tries to get it in to the hole that I could not see... don't mess up the roll pin by beating on it.
now put the shift ball and spring back in.
I learned this because I could not get the rear out put flange off, no matter how I tried. I even tried 4 foot breaker pipes, bars what ever.
so sat down and looked at the pictures in the manual for a long time before I saw what I could do.
catching the roll pin is important. cutting the rail is important, getting the shift rail and shift fork holes lined up to put the roll pin back in is important.
when installing the shifter.. have the two shift fork (holes) lined up to make a square.
install two bolts, one each side of the shifter and make sure that they move OK.
It is possible, I did it, to get the shifter fingers in front of the shift slots that they need to be in.
I tried the trail gear aw some shift springs and I could pick up the transfer case by the shifter and it was not shifting, to give you an idea of how hard or strong those springs are.
my wife could not move the shifters at all with out using both hands!
it should be mentioned that the heavy duty springs increase the shift resistance by about a factor of 10 times as much pull to shift!!!
I would, if you are worried about it jumping out of gear. stretch the stock springs, no more then 1/8 inch and install them.
I would only use the heavy springs if you have a problem with the case jumping out of gear, like in rock buggy racing where the weight of the shifter, and hitting something hard, will knock it out of gear.
also the shift boot and mount require tolerances that are very close. I marked and cut the hole about 1/4 inch off. It moved when I mounted up the transfer case cross member. I re cut the side that was hitting, the included mount ring is to narrow, and now have to make a new (boot ring) to cover that part of the hole.
I would like to see the present trail gear, mount ring included and a second mount ring about 1 to 2 inches wide included in the kit.
the present ring would go under the boot and be pop riveted to the wider, (go's on top) ring that I am suggesting.
For those of us that cut the hole to big!!
I hope that this helps others that are trying to go to the twin shift.
their write up with pictures.
http://www.trail-gear.com/pdf/107500-1-k.pdf
Old 04-14-09, 11:03 AM   #40 (permalink)
dieselcruiserhead's Avatar
TLCA# 9439
Really good stuff, pretty much covers it all as I've seen/read over the years...
- Cummins 4BTswaps.com Forums
- Hazard Assembly Dirtbag Adventuring Community
- Diesel Conversion Website
TLCA# 9439 Since 1999, Wasatch Cruisers
'89 Toyota Pickup V6, OME, 33x10.5's
'69 FJ55 Project on locked FZJ80 Frame, Cummins 4BT, NV5600, Dana 300
dieselcruiserhead is offline   Reply With Quote
Old 04-18-09, 08:08 PM   #41 (permalink)
cages are on the list for the summer, I will take pictures of what I come up with!!
LinkBack to this Thread: http://forum.ih8mud.com/79-95-toyota-truck-tech/257685-how-build-toyota-solid-axle-rock-crawler-thread.html
Posted By For Type Date
Moteur de recherche : Web, Photos, Videos, Voyages, Encyclopdie This thread Refback 10-16-09 12:34 PM
How to Build a Toyota Rock Crawler on Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback 06-27-09 12:41 PM
Hilux 4x4 Off-road Forum - View topic - NICE Mods to be done in the driveway This thread Refback 05-16-09 12:46 PM
