It's going in my 62 so I figured this would be the best place to ask...
Correct me if I'm wrong, but Toyota's master cylinders are set up so the forward fitting goes to the front brake lines and the aft fitting to the rear lines IIRC.
I saw that Sky Manufacturing offers an adapter that allows bolting a GM master cylinder to a Toyota booster. Sounds like a simple plug n' play setup, right? Problem is, I don't know if GM master cylinders are set up the same way Toyotas are (ie: front/front and rear/rear), or if they're reversed like how Chrysler MCs are (front fitting to rear brakes and rear fitting to front brakes).
Anyone know which is the case for a GM MC?
