Just finished up building my HD skid plate and figured it was time to post some pics.
After smashing my stock skid plate I decided it was time to find a heavy duty replacement. I also wanted a project that I could cut my teeth on learning how to weld so I decided to build my own.
I have to give props to bsevans design because I based my design on his build although I did not have access to machine shop to bend 3/8" plate nor a laser cutter so mine would not be as professional looking.
Where to start? I wanted it my skid plate to be flat and have the minimal amount of drop from the frame rails. I started with a 3'x5' sheet of 3/8" plate steel and a few other misc. pieces. I had my brother-in-law cut the pieces to length with a plasma cutter but the cuts were pretty rough. I will definitely need a better solution for making cuts. More on that to follow!
First step. Cut out all the pieces, weld frame mounts and weld to skid plate.
