West Aussie FJ40 Build
Perth WA
Hi All,
Been reading ih8mud for a while now and referring to tech articles so though id post my build
Its a 1972 FJ40 with a 307 Chev
this is it as i picked it up
First thing i did was start cutting rust out and stripping it down the floor was pretty bad so i cut that out
Ive welded in plates and bogged over them and primed most of it also welded in a new floor, a mate is a sheet metal worker so he helped out with fabricating the new floor, also dropped the diffs out
I got some 60 series diffs under there now which will extend the width and also gives me front discs and rear LSD . im in the process now of getting all the new bits together so i can start welding spring hangers back on
thanks to dieselcruiserhead as his post was really helpfull. I hope ive done it correctly
https://forum.ih8mud.com/40-55-seri...w-put-60-series-axles-under-40-55-series.html
Nice work mate! I don't know if I could drive anything from the right side hee hee!:cheers:
Yeah haha id be the same if i was in the US i guess, id find it worst changing gears with a different hand i think ;)
So can anyone who has done this conversion tell me do you use the 60 series relay rod or 40?
I assume its the 60s but when i got the diff it didnt have a complete relay rod its missing the bit that threads in the end
just wanted to make sure if i get one im getting the right thing cheers :)
Hi All:
Ibrodie, nice build, thanks for sharing with us! :beer:
Regards,
Alan
A few days and you'd have it figured out...
It does get a little confusing when you're driving a truck with both drives and you're switching back and forth every ten minutes. :D
Your build is coming along nicely.:cheers:
So can anyone who has done this convertion with 60 series diffs into a 40 series tell me what happens with the relay rod?
At the moment i just have standard steering so the 60 series relay rod dosnt fit..... and the 40 series relay rod dosent fit the 60 series diff :bang:
