treerootCO
Where are my keys?!
I had, past tense, no brakes and I wanted to make the snow run this Saturday. We bled everything with a vacuum pump, then old school with someone inside on the pedal. If I hit the pedal after waiting a few, engine on or off, it would go to the floor. If I pumped it up and held it, the pedal would slowly go to the floor.
I figured it was the master so I bought another. No Aisin at NAPA, Toyota, or Carquest... Went with new NAPA because the dealer said he couldn't get one. I just finished the install and bled everything again. I made sure to bench bleed the master.
Pedal is much happier now. I can stand on it and maintain pressure. Problem is I still can't crowd the brakes in an emergency. It takes two or three pumps to stop the 40.
After a few hours adjusting the rear pads...I POR15ed the drums to the axle and the adjuster would not budge...I tightened everything so I can spin the tire one revolution before it stops.
Back on the street to terrorize the neighborhood at 11:30 at night. I can actually stop again...the pedal is much higher, one pump to pitch the car forward enough to unload the ass end and lock the rears.
I still can't crowd the brakes on the first stomp. 12/78 production, huge booster. I did the FSM tests on the booster and I think everything is good there.
Brake lines are all stainless up front. The only rubber hose is brand spanking new. No leaks anywhere. Pads front and rear are new. Is this just the way it is or did I miss something?
