01-31-07, 02:42 PM
#1 | | Site Addict
| 2F + 3FE = 2F-ETI Into My FJ40 Well after reading a few threads on grafting a 3FE head on to a 2F block we have decided to go the whole 9 yards and return the punt for a touch down and build an injected turbo water inter cooled 2F.
I already have a worked 2F that rocks that's been rebuilt and balanced, tomorrow I pick up a 3F-E complete for $200us that was pulled out and replaced by a 350 in an 80 series . It was running when removed too.
My 2F, the last dyno run. So we know where we started.
First up will be to remove the 3F-E head and have it worked, ported and polished plus what ever else it need to suit the turbo.
So for those interested watch this space for a detailed write up.
TEC SPECS COVERED SO FAR IN THIS THREAD. I will up date this as the thread progresses in RED links in ORANGE 3F-E Head ported polished larger flat faced Ferrea valves and flow tested before and after. Con Rods for a Jaguar 4.2 straight 6 will replace the stock 2F rods Pistons JE Custom ECU Wolf V500 Turbo is a by Garrett GT30 82R Valve Springs by Crow Part No4832 ARP Con Rod Bolts Part No 154-6001 Wastegate Tial 44mm Home Brew Intercooler Air to water Jet Hot Ceramic Coatings TLF Performance Parts 550cc Injectors Davies Craig Electric Water Pump for the Intercooler
READING New Features compares the 60 series 2F with the 62 3FE
__________________ DYNO'd at 8PSI 181kw/244hp & 560Nm/413ftlb @ the RW 8th Dec 08
EST @ FLY 283KW/379HP Links Advanced (HB) Intercoolers
01-31-07, 02:45 PM
#2 | | Site Addict
Join Date: Aug 2005 Location: Corpus Christi/Austin, Texas
| Should be interesting.
Lookin forward to it. |
01-31-07, 02:48 PM
#3 | | In the garage
| Could you explain what that means for those of us who are dyno and metric challenged? I read it to say that peak torque is reached around 3000 rpm then levels off? I look forward to seeing this build up thread.
__________________ 79 FJ40 & 78 FJ55 |
01-31-07, 02:55 PM
#4 | | Forum Lifer
| Quote:
Originally Posted by John Smith Could you explain what that means for those of us who are dyno and metric challenged? I read it to say that peak torque is reached around 3000 rpm then levels off? I look forward to seeing this build up thread.  | Peak Torque @ ~2000, peak HP @~3000-3500. (Lines are labeled P and T).
__________________ Doug G
Seattle, WA
TLCA#12671
1994 fzj80, 295,000 miles, 285X75/15, Billy's, dual batteries, daily driver
1987 fj60, 310,00 miles, 3" lift, 1" BL, 33X10.50's BFG MT, dual battery, rear drawers, CB, tuffy, lockright, 4.10's, H41 |
01-31-07, 02:57 PM
#5 | | what he said
| So you max out the RWHP at 100 (75 KW) correct?
With 368 Ft lbs of torque? (500 nm)
interesting..
I hit 140 hp and 220 ft lbs in my rig.
How did the torque numbers get so high without much increase in HP?
__________________ I am kinda gay.......
I've set the bar, don't trip over it....
"Mary Poppins: In every job that must be done, there is an element of fun. You find the fun and - SNAP - the job's a game." |
01-31-07, 02:58 PM
#6 | | Amazed and enthralled
| I'm assuming from the torque/power curves that this must have been with a stock camshaft.
Any induction, exhaust or compression changes to that engine?
What sort of loss are you attributing to the drivetrain (what sort of flywheel numbers do you think these approximate)? |
01-31-07, 03:00 PM
#7 | | Site Addict
| Quote:
Originally Posted by lovetoski Peak Torque @ ~2000, peak HP @~3000-3500. (Lines are labeled P and T). | Red is Gas Blue is LPG as for the Metric coversions sorry I'm imperially challenged
EST @ FLY 283KW/379HP Links Advanced (HB) Intercoolers |
01-31-07, 03:05 PM
#8 | | 250+ Club
| Wow you got more power on propane? I'm asssuming you must have adjusted the timing when switching right? Is there anything else you did?
I run gas and lpg in my cruiser too but I don't think I have a power increase with the propane. |
01-31-07, 03:09 PM
#9 | | Site Addict
| The original 2F was built and cammed for low down torque on LPG the head was skimmed and a few other bits. So it's tuned for LPG
This engine was built for torque not hp to turn 35's. Diffs are 4.556 too.
30 spline Longfileds in the front as we snapped a stock CV every trip out.
01-31-07, 03:19 PM
#10 | | Amazed and enthralled
| I've got a 2FE-T cooking on a back burner myself. Down the line a bit, so I'll be watching your build with interest.
Mark... |
01-31-07, 05:19 PM
#11 | | Site Addict
| First the engine builder wants the 3F-E head which is stock to calculate the volume and compression from there he will if needed open it up.
It seem that to get more out of the turbo it may be better to de-compress the engine, rather than incress it. All this can be done while its been ported and polished.
Big learnig curve for myself here too.
New forged pistons will be needed as well as con rods. Crank I'm told is not an issue cam has not yet been discussed.
Now where is my credit card
I'll take pics of the 3F-E head before it goes to be machined and post up a full list of the modifications and after pics.
01-31-07, 05:39 PM
#12 | | Amazed and enthralled
| I don't think you will need any change to the connecting rods. Rod bolts are the weak link.
Nominal compression on a 2FE *should* work out right at 9.0:1 A little on the high side for a turbo, but it you're gonna be running an intercooler it should be okay.
Mark... |
01-31-07, 06:12 PM
#13 | | Site Addict
| Quote:
Originally Posted by Mark W I don't think you will need any change to the connecting rods. Rod bolts are the weak link.
Mark... | Just off the phone with the turbo people they would like the engine to make around 8.0:1 so that's sorted if need be the head will be opened up to achive the required compression.
Also to run boost up to 20 psi I should have the the head or block O'ringed
I'm learning real fast.
01-31-07, 07:52 PM
#14 | | Amazed and enthralled
| Yeah I was assuming a max boost of 15 psi. I'd be happy as hell to make that work.
Mark... |
01-31-07, 09:32 PM
#15 | | what he said
| 20 psi is nuts..
stick with 12-15 psi boost...
at 2000' elevation with a 8:1 compression ratio under 15 lbs of boost you will have an approximate effective compression ratio of almost 16:1
At 20 psi you are lookin at about 19:1...
01-31-07, 09:43 PM
#16 | | Amazed and enthralled
| But the concerns of a supercharge making cylinder pressure in conjunction with the pressure made by the compression of the piston moving up are not the same as an equal amount of presure made by compression alone. And an intercooler reduces the equvilency even further.Cylinder temps and detonation is not the same because of the amount of heat actually generated outside of the combustion chgamber and (in the case of an intercooler) shed there too. Not to say that even 12psi of boost is not a LOT.
Mark... |
01-31-07, 10:10 PM
#17 | | Site Addict
| yea.... my 87 supra turbo is running at what..... 6-8PSI?!?
__________________ Chris Basehore TLCA# 4821 74 FJ40- built F, knuckles/brakes from a FJ60, Longs, 4" Pinnacle sucks big wads, mini PS, shite paint 93FZJ80 "klunky"- E-lockers, home built sliders, IronPigOffRoad bumper, CDL switch, D-less, mucho maintenance www.ILUVROCKS.com |
01-31-07, 11:17 PM
#18 | | Site Addict
| Without adding the O'rings to the head or block the turbo people here only recommend a max of 10psi. It's seems the O'rings aid the cylinder head gasket so a higher boost can be run.
Like I said before I'm learning as I go. but for myself I think 15psi max would be the go rather than pushing the limits too far.
Other issues I have yet to address are fuel pumps and gas convertors to cope.
01-31-07, 11:43 PM
#19 | | Amazed and enthralled
| Considering that 15 psi will basically double your power... Yeah, I'd say that's plenty and I'd be more than happy to reach that level. (Don't forget that there's a lot of room to boost the power of a 2F BEFORE you get stated with boost!)
Before anyone lurking this thread jumps in with smarmy comments about polishing a turd or the old "put a smallblock in it"... Same reason mountains get climbed... Because it's there.
Mark...
Mark... |
02-01-07, 01:31 AM
#20 | | Site Addict
| Quote:
Originally Posted by Mark W Considering that 15 psi will basically double your power... Yeah, I'd say that's plenty and I'd be more than happy to reach that level. (Don't forget that there's a lot of room to boost the power of a 2F BEFORE you get stated with boost!)
Mark...
Mark... |
I get all the V8 comments and not a cat in hells chance, the look on someones face with an all powerful V8, been beaten at comp by a 2F is PRICELESS
Some of you may have seen this before its posted here and there on this forum. Me at play on my AT's http://scotto.3rdrock4x4.com/MattMc40.mov
As you can see My current 2F turns 35's nicely
| Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | |
LinkBack to this Thread: http://forum.ih8mud.com/40-55-series-tech/134529-2f-3f-e-2f-eti-into-my-fj40.html | | Posted By | For | Type | Date | | My E34 535i - Page 2 - Bimmerforums - The Ultimate BMW Forum | This thread | Refback | 05-25-10 05:55 AM | | Toyota Landcruiser 1980 SWB (4x4) (eBay item 320532410520 end time May-21-10 15:37:13 EST) | This thread | Refback | 05-20-10 10:37 PM | | Toyota Landcruiser 1980 SWB (4x4) - eBay, Passenger Vehicles, Cars, Cars, Bikes, Boats. (end time 21-May-10 15:37:13 AEST) | This thread | Refback | 05-18-10 05:33 PM | | Toyota Landcruiser 1980 SWB (4x4) (eBay item 320532410520 end time May-21-10 15:37:13 EST) | This thread | Refback | 05-15-10 02:46 AM | | My E34 535i - Bimmerforums - The Ultimate BMW Forum | This thread | Refback | 05-12-10 03:40 AM | | Toyota Landcruiser 1980 SWB (4x4) (eBay item 320528310658 end time May-14-10 11:29:17 EST) | This thread | Refback | 05-10-10 03:19 AM | | Toyota Landcruiser 1980 SWB (4x4) (eBay item 320528310658 end time May-14-10 11:29:17 EST) | This thread | Refback | 05-09-10 12:15 AM | | Toyota Landcruiser 1980 SWB (4x4) - eBay, Passenger Vehicles, Cars, Cars, Bikes, Boats. (end time 14-May-10 11:29:17 AEST) | This thread | Refback | 05-06-10 07:35 PM | | Untitled document | This thread | Refback | 05-06-10 07:16 PM | | turboed 2f - Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips. | This thread | Refback | 12-30-09 06:25 PM | | turboed 2f - Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips. | This thread | Refback | 12-30-09 04:15 PM | | turboed 2f - Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips. | This thread | Pingback | 12-27-09 11:27 PM | | [3FE] Re: 3FE Turbo | This thread | Refback | 05-04-09 03:09 PM | | Turbo or Supercharger on 3F Cruiser? - Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips. | This thread | Refback | 04-11-09 09:19 PM | | Turbo or Supercharger on 3F Cruiser? - Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips. | This thread | Refback | 03-15-09 03:05 PM | | FOROS DE NUESTRO CLUB • Ver Tema - Potenciación exitosa | This thread | Refback | 03-11-09 08:50 AM | | 2F Turbo/Super Cargado - foro.cruiserheads.com | This thread | Refback | 03-10-09 01:29 PM | | Laminova water to air intercooler - Page 3 - Patrol 4x4 - Nissan Patrol Forum | This thread | Refback | 02-21-09 04:57 PM | | 1hz flow rates - Pirate4x4.Com Bulletin Board | Post #0 | Refback | 12-29-08 07:06 PM | | Chilled intake...? - Page 3 - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 11-30-08 08:34 AM | | Outer Limits 4x4 Board :: View topic - changeing 3FE auto to 3F carby manual | This thread | Refback | 11-07-08 11:50 AM | | The Best Carb? - Pirate4x4.Com Bulletin Board | This thread | Refback | 07-14-08 01:28 PM | | 2f + 3f-e = 2f-eti Fj40 - Rising Sun Member Forums | This thread | Refback | 06-05-08 03:04 AM | | Untitled document | This thread | Refback | 05-11-08 11:39 AM | | The Best Carb? - Pirate4x4.Com Bulletin Board | This thread | Refback | 04-15-08 11:46 AM | | The Best Carb? - Pirate4x4.Com Bulletin Board | This thread | Refback | 04-11-08 09:00 AM | | Toontoys Forums :: View topic - WANTED - BJ60 Land Cruiser | This thread | Refback | 03-09-08 09:12 PM | | 1983 FJ45 Troop Carrier Buildup - Page 24 - Expedition Portal Forums | This thread | Refback | 02-21-08 06:19 PM | | 1983 FJ45 Troop Carrier Buildup - Page 24 - Expedition Portal Forums | This thread | Refback | 02-21-08 11:29 AM | | Outer Limits 4x4 Board :: View topic - 6cyl stroker kits | This thread | Refback | 01-22-08 02:57 PM | | Turbo 2f... - Rising Sun Member Forums | This thread | Refback | 12-20-07 12:39 PM | | Outer Limits 4x4 Board :: View topic - 6cyl stroker kits | This thread | Refback | 12-16-07 11:34 PM | | Outer Limits 4x4 Board :: View topic - 6cyl stroker kits | This thread | Refback | 12-16-07 07:27 PM | |
