03-31-05, 06:12 PM
| | Site Addict
| LX470 Cabin Air Filter Replacement DIY Perform steps 1-3 first to inspect whether you have the access doors or not before ordering filters!!!
Did this little project this evening. Figured I'd write it up.
5 Easy steps:
1. Remove glove box door by removing both screws at the bottom of the door.
2. First pop the the little flap with a fuse/relay out of the black plastic shield in the upper portion of the glove box opening. Next push it back behind the shield through the opening. Next remove the 3 screws holding the shield in place. Don't pull this shield out yet!! Read step 3 first.
3. Gently pull the shield out. Be careful because the glove box light is still plugged into this part. It is located on the right side of the shield. Once it is pulled out slightly, unplug the bulb from the harness and now you can fully remove the part.
4. Now you can see the vertical cover where the air filters reside. The cover is about 5 inches tall and about 1 inch wide. It has 2 tabs on the upper portion of the cover. Squeeze these tabs towards each other and pull the cover off.
5. The filters are now exposed. They are stacked on top of each other. Pull the first filter out then lift the next filter up and pull out. Put new filters back in and reverse the procedure.
Parts needed:
2 Cabin air filters (Toyota PN 88568-60010 if you drop CDan a pm)
1 Phillips screw driver
Time needed:
No more than 15 minutes
Mechanical Difficulty:
EASY
Step by Step Pictures: http://www.abescastle.com/LX_filters/index.htm
Tad Abraham
__________________ Tad A.
99 LX470 - Slee Sliders & 34" Swampers, 182k and counting work truck.
03-31-05, 08:59 PM
| | Forum Regular
| Very easy as you described. I found that my '99 I've owned for a year now has no filters!! My intent was to see how filthy they were- I'll have some in pronto. |
03-31-05, 11:28 PM
| | Forum Regular
| I'm also very disappointed to see that my lx did not have any filters in there ! the last time the lx was at the dealership I had specifically asked them to check if they need replacement. Had i not checked i would've never known. bad service from lexus. but nevertheless, i'll put new ones in now ! |
04-01-05, 07:05 AM
| | Site Addict
| All right, probably dumb question, but when did the LC get cabin filters? Anyone know?
__________________ Scott
Granbury, TX
1987 Beige FJ60.
One clean cruiser. |
04-01-05, 07:19 AM
| | Site Addict
| Was not part of my 90k service. Has yet to be recommended?
__________________ "May you be in heaven a half an hour before the devil knows you're dead"
1992 4x4 PU |
04-01-05, 07:36 AM
| | Site Addict
| I think this may be LX470 only. I believe the LX470 has had this since the '98 inception.
Man guys, 0 for 2 on the filters! Mine were black instead of bright white and had what I call "pecan doodles" in them from when the Pecan trees pollenate. Hard to believe that trash would make it that far in.
99 LX470 - Slee Sliders & 34" Swampers, 182k and counting work truck. |
04-01-05, 08:05 AM
| | Forum Regular
| I have found references to LC having them in 2000 - 2001
I would like to know about LC having them also.. |
04-01-05, 08:19 PM
| | That 25 Guy.
| None found when I was servicing the '00 LC tonight.
There will be before the pollen flies.....thanks Tad.
__________________ Jim FJ25.com
"The FJ25 is almost humorous in its simplicity, but therein lies its beauty." Nina Padgett - Autoweek |
04-01-05, 10:09 PM
| | Forum Lifer
| Can you retro fit a cabin filter to a '99 LC 100? |
04-02-05, 10:34 AM
#10 (permalink)
| | That 25 Guy.
| Takes about a minute to drop the glove box door (five minutes for the screwdriver impaired) and compare it to Tabraha's picture, if the trapdoor for the filter is there, then yes.
04-02-05, 12:56 PM
#11 (permalink)
| | Forum Lifer
| If I wouldn't have been in such a hurry in the first place I would have saw Tab's photo link ("the faster I go the behinder I get"). I pulled my glove box and the slot is there sure enough. Just e-mailed CDan to order. I assume, by Tab's instructions this slot will hold two filters?
Thanks!!! |
04-02-05, 04:54 PM
#12 (permalink)
| | Site Addict
| CDan's gonna be on backorder soon!!! I can't believe how many of you guys don't have ANY filters!!
Tad Abraham
04-02-05, 08:48 PM
#13 (permalink)
| | 250+ Club
| Sure enough, my 2000 LC has the access door but no filter cartridge. Does anybody know what type of media is in the cartridge? I'm assuming it is either a high efficiency particulate air (HEPA) fiber filter for removing small particles like pollen or an activated carbon pack for removing fumes and odors like diesel exhaust and essence of skunk. If there is space for two cartridges, it would be good to have one of each. The part number listed in an eariler post (8856860010) comes up on www.toyotapartscheap.com as a "filter, air" for $20.96 (list $26.20). It doesn't specify if one or two are required or the type of media.
__________________ jp
2000 UZJ100@150Kmi, stock |
04-02-05, 08:51 PM
#14 (permalink)
| | Forum Regular
| so this is what i'm curious about, as now there are other posts mentioning that there are the compartments but have no cartridge. were they taken out by the service dept. and never replaced ? or were they taken out by previous owners ? ... |
04-02-05, 09:03 PM
#15 (permalink)
| | 250+ Club
| I have the same curiousity. I bought my 2000 LC used with all the dealer service records. No mention of replacing the ventilation air filter. I'm beginning to think the factory never put them in; perhaps they were out of stock. Maybe a class action law suit is in order! I wonder if Toyota USA and/or Toyota Japan monitor this forum. If you are, I want my filter cartridge!!!
04-03-05, 07:18 AM
#16 (permalink)
| | 250+ Club
| Where's a web site showing Toyota cabin air filters but nothing listed for the LC. For some models there are two types of filters available; the standard type and the elctrostatic charged type for removing even smaller particles. http://www.houstontoyotaclub.com/ima...ilters%202.jpg
04-03-05, 11:36 AM
#17 (permalink)
| | Forum Lifer
| In the cabin filter 'bay' on my '99 LC100 it appears one of the filters must rest on top of the other? It, due to the air path being on the bottom of the door slot, looks like this must be the case. It is difficult to imagine, without the filters of course, to see how the filters rest inside this compartment. When I get the filters I'll let all you LC owners if and how it works...
__________________ Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery with custom home brew battery tray, home brew sliders & Slee belly and skid plates, 9.5XP/Masterpull, Solstice LEDs, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, LT285/75R18 GY MT/R Kevlar, KK in tow... HAMified
ROTM: http://forum.ih8mud.com/100-series-c...pressomon.html |
04-03-05, 03:20 PM
#18 (permalink)
| | Site Addict
| Quote: |
Originally Posted by jp213a I'm assuming it is either a high efficiency particulate air (HEPA) fiber filter for removing small particles like pollen or an activated carbon pack for removing fumes and odors like diesel exhaust and essence of skunk. If there is space for two cartridges, it would be good to have one of each. The part number listed in an eariler post (8856860010) comes up on www.toyotapartscheap.com as a "filter, air" for $20.96 (list $26.20). It doesn't specify if one or two are required or the type of media. |
It is a HEPA paper/fiber filter. The filters sit stacked one on top of the other, 2 high. Look very closely in the "step 5" picture and you will see me pulling out the top filter with the top tab of the lower filter barely visible underneath. They are identical parts so order a quantity of 2 for a single changeout.
As for the carbon filter; that would be worth pursuing. The automatic circulation sniffer works great for everything except skunk, it won't catch that but mine works very well at catching 4 wheeled stinkbombs before they get into the cabin.
Tad Abraham
04-03-05, 05:30 PM
#20 (permalink)
| | Forum Lifer
| Thanks Tad for the info. One more: How does one get an email to Cdan?
