do92fj80 said:MOst of the common problems that I have encountered with 100series check engine light is the gas cap is either not properly installed or my be time for a new one. The EVAP (charcoal canister) is supposed to be pressurized, if the system detects low, or no pressure it will give a check engine light.
I do agree to get it check, however autozone does not check it for free (former employee) but they do charge a deposit of $182.00 (approx) to rent the scanner in which you will get a full refund once you return it, so the rental is free. Make sure you have an experienced employee check it to avoid them screwing something up. It has happened.
donco said:Too many possibilities to troubleshoot without a code reader. Could be an O2 sensor or a dead injector or coil. Best to have the fault code(s) read before swapping out components.
Autozone will read it for free and will zero in on the exact problem. Most of the Check Engine Light issues are emissions related components but some are more serious and will affect driveability and gas mileage.
You can get an inexpensive code reader at Harbor Freight for $39.
hoser said:On US market vehicles, the OBD2 connector is always in the interior, within 3 feet of the driver, but most often in the footwell, near your left shin/knee but sometimes on the transmission side. No special tools to access. The connector on the hood labeled "diagnostic" is not it.
