How does torque power compare for a Milwaukee m12 vs a 3/8" Balkamp air ratchet?
That number seems low. The Milwaukee website says 41.
http://www.milwaukeetool.com/power-tools/cordless/2452-20
I agree that air wins for raw power, although some of the 18v versions are in the 300-400 ft lbs range. OTOH the 18v impact I have (the little one for driving screws) is super handy around the garage for working on cars. It's rated at 125 ft lbs, and I use it almost exclusively now because it's so much more convenient than getting out the air powered impact. All the little stuff zips off quick and I use a regular old ratchet for the larger bolts. The only time I get the air impact out now is to rotate tires.
I have a milwaukee M12 3/8 ratchet and it is the best tool buy I've ever made.
I can break the bolt loose by turning the ratched as a whole, then take off the bolt in a matter of seconds. Then I can put the bolt back on with percise control to just snug it up. Then I either tighten it by hand our use a torque wrench..
I never use my air tools anymore.
I have a couple air ratchets that I never use anymore. Whenever I did use them they seemed so weak that you had to break loose or tighten the bolt or nut by hand anyways and the noisy air ratchet would slowly turn the bolt or nut after. I love my cordless tools, and my air impacts for working on stuff.
