Zipping sound under acceleration?
Golden, CO
The sound is a zipping or like a low pitched prolonged honk. It sounds like rubber pressing against something that is rotating fast. No screech at all.
It only happens under hard acceleration, generally going uphill. It happens when accelerating from a stop or when accelerating while already going 20 or 30 mph or at highway speeds.
It does not happen every time I accelerate hard. I'd say maybe 10-20% of the time. I can't figure out a way to reliably reproduce it and I've tried pretty hard.
Once the sound starts, it lasts while I keep my on the gas. The sound persists if I accelerate. If I let my foot of the gas, even if it's just for a second and then I immediately reapply, the sound goes away. It's almost like two parts are slipping and if I give them time to catch up the slipping goes away. That makes me think it's something in the transmission, but I don't notice any power loss while it's happening. The transmission fluid looks fine but I haven't replaced it. I tested the viscous coupler and it also seems fine.
I thought I had it nailed when I noticed the muffler was rubbing on the driveshaft due to broken exhaust mounts. I replaced the mounts, but the problem is still there. It might be slightly better but it's hard to tell with how random it is. It was extremely difficult to rotate the exhaust back to where it should be to get the mounts on. Also the rubber mounts look like they're straining to hold the muffler off the driveshaft, so maybe that's still the issue? I don't have an OEM mount at the tailpipe since the PO cut off the resonator, so maybe it's not held in place properly. I definitely have a mean whistle at high RPM due to the lack of resonator, but this is a different sound than that.
I've had the sound since I bought the truck. Since then I've done a front and rear axle service including brakes. I've replaced the u-joints and had the driveshafts balanced. None of those things made any difference.
So there's my long winded explanation. Anyone else have symptoms like this or have ideas what it might be?
I've had something similar but I would describe my noise as a fast ratcheting. It originally occurred on a slippery winter day when I was accelerating up a fairly steep curvy road in my complex and ran over a sewer grate. Since then it seems when I briskly accelerate from a right hand turn it reoccurs, more so in colder weather. I was thinking it may be the front output section of the transfer case or the slip yoke in the drive shaft as the right front is going to rise up further and extend the on the right turn. Never have the problem on left turns.
Interesting. Mine is a smoother sound than a rachet. Yours sounds like maybe a clicking birfield.
Could be any number of vibrating parts on the car. Does it vary with speed? Does it have any other symptoms like a loss of power? Temperature dependent? Is it loud enough to record?
It happens at various speeds. I believe it does increase in pitch if I accelerate through it. There are no other symptoms, just the noise. I haven't made a concerted effort to record it. I may try that next. I've thought about trying to use a small microphone placed in different locations so I can narrow down where it's coming from. Maybe I can hook one up to an iphone or computer or something.
Darkness,
can you re-create this sound in reverse going uphill or against a load? Maybe back to the edge of a sidewalk, put her in Reverse, in 4Hi, then try to climb the curb and see if you can recreate this sound?
Maybe I missed it, but have you tried to duplicate the sound while parked by very slowly increasing rpms? A lot of times heat shields/fans etc will make strange noises at specific rpms.
I haven't tried, I'll give it a shot. What's your thought there?
Depending on what the manuf date is on your 80, some '97 model trannys experience this "zipping" sound, particularly while backing up against a heavy load. A TSB is out on some of these trannys and discussed on this board. A ball is missing in the valve body that causes this slippage and sounds like a zipper.
This sound is very "strong" and can be felt through the cab I'm guessing.
Yeah I can sort of feel it in the gas pedal. I was aware of that issue but didn't know it affected more than reverse. I'll give that a shot tomorrow. Thanks. Mine's a 96 so it's in the range of years that have that problem.
'96 here. I also have the high pitched "zipping sound. I also had a zipping sound on my OG 91 LC and I if I remember correctly the Toyota dealership claimed it was related to the speedo cable.
Subscribed.
Yes, it does not make the sound neutral. Has to be under load.
'96 here. I also have the high pitched "zipping sound. I also had a zipping sound on my OG 91 LC and I if I remember correctly the Toyota dealership claimed it was related to the speedo cable. Subscribed.
Very very interesting. Thanks for the info. I'll explore this a bit when I get some time.
Correct, no speedo cable, has the sending unit attached to the transfer case.
Darkness, can you re-create this sound in reverse going uphill or against a load? Maybe back to the edge of a sidewalk, put her in Reverse, in 4Hi, then try to climb the curb and see if you can recreate this sound?
I tried reversing uphill and over a curb. No problems, no sounds.
ok, that's a good sign then.
I'm starting to think it might be a belt slipping. It was really really cold this morning. I started the car and it made the same sound for like 3 seconds immediately after startup while sitting in the driveway. It hadn't done that before. I'm used to belt slippage sounding like a screech, but maybe it doesn't sound like that way in this case for whatever reason. I may try tightening up the belts to see if that helps.
Oh wait, you just gave me a clue. The Zipping sound on startup on cold mornings and that is something lot of us get too!!! Some of us have that sound longer than others but it does go away after a short while.
I can't recall the cause of the sound but it has been discussed in the past.
Interesting. It sounds exactly the same as what I'm talking about. I wonder if it's a symptom of one of the many belt driven devices starting to go bad. I suppose it might also not be a belt, but it really seemed like that this morning.
