Zerc fittings
Sacramento area
Hey first post, I have a 88 4x4 22re 5sp manual standard cab, I just changed all four ball joint, and would like to put zerc fittings on them. Whose done it, where did you get the fittings, and what size.
Thanks
Did you use Moog ball joints? They already come with zerk fittings on them.
Either way every ball joint I've bought came pre-fitted with them. So you would just screw the zerk fitting in with a 8 mm ratchet when you've finished installing the ball joint and grease it before you hit the road.
Naw, Toyota bj.
Its got a threaded 10mm hex head bolt in the top.
I wanna find a zerc to replace that so I can service them easier.
I picked up some this morning, in both metric and standard.
The metric are not the exact size, but close enough, thread-wise, to work.
I decided I will use the zerc to sevice them then switch back to the one that came on the bj for everyday use.
