YWST: Long Spline Split T-Case Input Gears - In Stock!
cruiseroutfit
Supporting Vendor
Moderator
Utah
Website
cruiseroutfitters.com
Got the T-Case clunk? We've got the fit!
Yeah, We Stock That!
These long spline t-case input gears replace your stock input gear and PTO spacer/gear to create an internal 19-Spline surface that is approx 90mm long. This eliminates that common drive to reverse clunk that results from worn splines both on the original input gear as well as the output shaft of the manual or automatic transmission.
(Gears shown with cosmoline coating to protect gear in shipping)
This is the problem (note damaged splines)
(Photo Courtesy of ih8mud)
Common US Applications:
8/80-4/86 4Spd Manual (H42) w/34mm Idler Shaft (OEM# 36212-60040) - Part# TCG60040L
4/86-1/90 4Spd Manual (H42) & Auto (A440F) w/38mm Idler Shaft (OEM# 36212-60080/36212-60081) - Part# TCG60080L
Non-US 5spd Man (H55F) w/34/38mm Idler (Call to Verify App) (OEM# 36212-60080/36212-60081) - Part#TCG60080L
More Information on T-Case Variations: Cruiser Outfitters
Also available and in stock for many non-US applications including 6x and 7x Series. Please call and we can verify your application. These do NOT fit any split-case applications with the side mounted PTO assembly, I have not attempted to fit them to anything with a rear mounted PTO unit, if someone has one of those and would like to guinea pig, I'm all ears. :D
Installation:
We offer all of the needed gaskets and seals individually and or part of our complete transfer case rebuild kits. At a minimum you will need the following:
1 x Trans to T-Case Seal (Various Applications) (Diagram# 36111B) - Part# TC48009/7/12/3
1 x Split T-Case Half Gasket - (Diagram# 36147A) - Part# TCGSK36143
1 x Split T-Case Rear Cover Gasket - (Diagram# 36142) - Part# TCGSK60030
1 x Split T-Case Rear Output Housing Gasket - (Diagram# 36152) - Part# TCGSK36152
1 x Transmission Rear Output Shaft Nut (Not Shown) - Part# TCN26002
1 x T-Case Rear Output Shaft Nut (Diagram# 36104D) - Part# TCN22005
IN STOCK & READY TO SHIP - Order Online @ CruiserTeq.com or call/email:
801-563-1277 - info@cruiseroutfitters.com
www.cruiseroutfitters.com
By request we another applications incoming, ETA is 4-6 weeks on our next stock order. I'm only bringing in one spare one to stock as we don't get many calls for this variety (and the cost a few more bucks). Let me know if any of you have interest in this one?
TCG60080LPTO - TC Input Gear - Split Case - 32T Long Spline (WITH PTO)
i've a HJ61 with the PTO output and A440F tranny will your gears fit my Tcase? all the tech manuals that i've got are saying i've either a h41 or h42 tcase. How do I tell the difference? also wanting bearings, gaskets and seals. also looking for the output shaft to run winch
Are you currently running the PTO, i.e. you have a winch on the front? Plans to keep it that way? Unfortunately the gears we have in stock will not work with the side mount PTO as it eliminates that gear. That said I'm pretty sure I can order a PTO style if your interested. Alternatively you can have your current PTO gear welded to your input gear to correct.
We would need to know the # of teeth on your input gear, that will ultimately determine which gear you use.
H41/H42 is the maual trans and the 32/34 T-Case could have come attached to either.
Do you have a VIN you can share? We can likely determine which gear is needed based on your VIN.
Still learning these HJ's are hard to get info on. The VIN plate under the hood reads
MODEL: P-HJ61V-PEMZX
ENGINE: 12H-T 3980cc
FRAME No: HJ61-007486
trans./axle A440F / ko82
Cool, nothing I can do from home today but I'll be back in the office and in front of part numbers tomorrow and will see what we find.
So that is a 1/1988 JDM Spec HJ61
That would use:
4/86-1/90 4Spd Manual (H42) & Auto (A440F) w/38mm Idler Shaft - Part# TCG60080L
As noted it will NOT work with a PTO offering. We do have those coming as a future offering but no firm ETA as of yet as sales demand has been low.
We had a major re-fill of these arrive earlier in the month. We've been calling back-orders but will still have quite a few available for new orders in both the 32T and 34T variant. Let us know if you've got a "clunk" you're looking to resolve :D
These are now available for online ordering @ CruiserTeq.com (click part number below)
Fits 8/80-4/86 4Spd Manual (H42) w/34mm Idler Shaft - Part# TCG60040L
Fits 4/86-1/90 4Spd Manual (H42) & Auto (A440F) w/38mm Idler Shaft - Part# TCG60080L
Fits Non-US 5spd Man (H55F) w/34/38mm Idler (Call to Verify App) - Part# TCG60080L
Any chance you'll do an overdrive set? I'm interested in this, but I'd like the long collar to avoid getting the spline clunk in the future.
100% agree, I sell and install dozens of the OD gears and would love a long-spline version. I doubt it will happen though. That being said most of the time it is also onto a new H55f so new output shaft + new gear = tight for +100K miles.
I actually wound up emailing Sumo Gear, and this was their reply:
"It is our intention to transfer over to the full spline input gear however, we still have a significant amount of stock of our current design, so I do not anticipate that happening in the near future."
We've lit the fire! I had dinner with them this last weekend. Lots or good stuff in the works.
