- Joined
- Dec 20, 2007
- Threads
- 133
- Messages
- 1,138
- Location
- Orcas Island in NW Washington State
- Website
- www.mtpickettwoodworking.com
Many of you have viewed my thread from a few weeks back about my quest for an 'easy' way to reduce or eliminate the wear on my '78 H42 four speed output shaft. I feel that the title was a bad choice for later searches, and the format was, well 'wordy' to say the least. I had hoped to locate an internally splined coupler or sleeve that matched the 32 mm dia, 16 involute spline so I could fabricate a long gear to bridge across the spline wear, supporting the gear on both sides. There is 5/8" of unused splined shaft beneath the oil seal surface on the trans side, and the tcase opening will accept a gear of 2 3/8" in length. This new gear would have 1 1/4" of balanced drive surface as opposed to the OEM's 7/8". Today I decided to cut my mockup to the 2 3/8" dimension length just so I'd have a model of what I have in mind. This model is made from a discarded u-joint slip yoke and has the required 16 splines, but paralell tooth splines, not involute, and slightly larger outer dia. I would like to see this design (with correct splines and made in one piece) brought to the attention of Taiyo Kiko (Seamaster) Gear or someone that might have interest in producing such a gear. If nothing else, I have talked to a small machine shop that specializes in internally splined couplers of any configuration and I'd use this to turn a shouldered weld-on sleeve to drive my existing gear. I took some photos of this morning's efforts that show an overview of what I came up with.
If one was willing to open up the t-case a bit more as shown in the shaded areas, a gear with an overall length of 3 1/8" could be installed.
