Yet another NEWBEE with a Question
Statham, GA
I finally decided to get my feet wet, or rather muddy, and go ahead a post-up my first thread and introduce myself. My name is Tony. I am a first time 80 owner, and lovin' it.:) I've had the cruiser for about 2 years. I bought the cruiser with 135,000 miles on it, now it just turned 168,000. I haven't had any major problems, ..... until, well, about a month ago it started pinging, the mileage droped, lost some power, rear main now leaks, and bubbles in the oil.
All symtoms of the same problem? Several different problems? No problem at all, just getting old? Any ideas?
I appreciate any input. Thanks!
tONy
WOW.... 68 views...NO replies:confused:Is my question too veauge?(sp?) How about if I narrow it down to the thing that bothers me the most? When I check my oil, the oil on the dipstick has BUBBLES in it. This started @ a month ago. Any input would be great. I have searched the forum and the FAQ to no avail. I didn't know if I should be worried or not, but with my other symptoms, it's got me worried.:eek:
Thanks Again
tONy
Might have head gasket troubles, foaming oil might mean there is coolant in it. Rear main is just a leaking seal, fix it if it is bad enough to bother you, otherwise leave it alone.
YEA...
..............REAL REPLIES!!!!!!!
:bounce: :bounce: :bounce: :bounce:
I have been cahnging my oil ervey 3K to 5K miles. I check the oil at every gas fill-up, it is usually abit on the low side when I see the bubbles. My first thought was a blown head gasket.
I went to a shop and he said it's not water bubbles, so he dosen't think it's a head gasket. He said check my PCV system.
I then called two other shops, described the problem in the same way.....the first think out of thier mouth was PCV!
So, now I'm thinking I need to check the PCV system? Just a quess.
Does this sound like it could cause the problem?
tONy
Your pinging, loss of power and mileage might be O2 sensor related. Your bubbles might be related to the kind of oil you run.
We'll need more info such as oil viscosity, type, interval, filter, driving style, driving type, and a pic of the offending bubbles.
also, a blackstone report will tell you for sure if anything is amiss. The best we can do is speculate.
Good Luck,
Dan
If the O2 sensor is bad, woundn't that post a code? or not? The dealer just ran on Friday and said there were no codes.
The dealer doeas the oil changes, but since the real main is leaking, I just add the Wal-Mart W30 oil as needed between changes.
I'll see if I can get a picuture of the bubbles.
tONy
I did some research on testing the O2 sensor. I'll test it to see if it's bad.
Do you think the cheaper oil could cause the bubble in the oil?
tONy
I tested the O2 sensor and it reads 0.035-0.186 vdc. The info. I have states that it should be between 0.4-0.6 vdc.
The info goes on to state that if I disconnect the vaccume line after the throttle plate, the reading should be around 0.12 vdc.
So...if it is already reading below that.....my guess would be that the O2 sensor is faulty?
Plus, I still may have some vaccume leaks?
tONy
if they are saying it's the PCV, than change that stuff. Is this the 1FZ engine?
there is a grommet on the valve cover to replace and a couple hoses- that is the first easy step- maybe those are cracked/clogged?
check your accelerator cable for proper adj and tension,
make sure your air intake tube is not cracked and leaking (common) check for cracks inbetween the bellows
that's all i can think of right away, good luck!
I replaced the PCV valve and cleaded out the hose.....but the hose has a crack in it. Do I have to get the molded OEM hose, or will any "cut to length" vaccume hose work. The reason I ask, is that I would prefer the OEM, but when I was at the dealer on Friday, I gave them more then my $.02!!:mad:
I gave them more like $113 for an OIL CHANGE!!!! Sure, they at the cruiser, but said they need more time......"To try and find something wrong with it." They said it wasn't throwing any codes, so there wasn't any problems.:doh:
Needless to say, I don't think I an welcome back at my local dealer.:ban:
tONy
