Yet another lifted 80 thread:
SLC, UT
J's up front, heavies rear. Slee swaybar drops, CC bushings will go in within the next week or two, along with the brakelines. Pics to follow from the install crew.
1997 LX 450. Springs were WAAAYYY too soft for my liking...certainly firmed things up!
Front Before:
Front After:
Rear Before:
Rear After:
As things settle, and the front bumper is added, I will assess the need for a spacer to level it out again. Sits fairly level as it is now...
Sorry to post whore...Better check WC for your spacers :shotts:
CC bushings won't be enough correction.
OME shocks are fine to my liking. First 80 I had I did the OME CC bushings and still had that 'darty' feeling with the J spring lift. On my next 80 did the Slee plates to correct the caster and have absolutely no 'darty' feeling.
Well I want to maintain the good ride the LX has without the stiff shocks riding like a brick. I just am weary about OME shocks being too stiff. I ordered heavy fronts and medium rear springs friday so now Im going to need to decide on some shocks.
IIRC, the OME's all have the same valving, so all will 'feel' the same. If you're anal about that stuff check into Bilstien's shocks.
Mind sharing total cost? Looks great like that!!
