Yet again Transfer case problem
Orange County
Yes, I have more problem. on Sunday. I heard Bad stuff under there. I was looking at everything toady. And My york has play. Like a lot. So The drive-shaft moves up and down alot. The nut is tight. I'm guessing is like a bearing or something? Anyway to know few sure. Or is this thing going to go kaboom soon ?
Eric
Open it up and take a good look...yes it will go kaboom if you don't
It can,, has this happened before? are your angles drastic?
Is there fluid in the Case. If it's wobbling it's going to need to be rebuilt period. What else do you want us to tell you?
It could be possible to shim the rear output race but that would be a temp fix.
Take it apart and look at what is going on....you will then learn how it comes apart, and, will find out what is wrong with it.
Good luck!
-Steve
