Part of the joys of living out in the middle of BFE is figuring out internet. It isn't as simple as DSL or cable
I opted for the overpriced business fiber optic that ran in front of my house.
That involved installing equipment in the basement or more specifically in the crawl space:
First ATT had to pull the fiber optic line into the crawl space where I provided a 4x4 chunk of plywood. The small box in this picture is the "terminating" equipment. Yes, that is a dedicated 15 amp outlet box for the rest of the equipment.
Then they stuff their version of a "router" onto the plywood:
This large box is analogous to a cable modem or dsl modem... except for 'real' men
Then they walk away and say good luck.
Because it is in the crawlspace and not easily accessible from the office(two floor up), I installed a remote power center for it:
I also opened it up to plug in some wires.
All said and done, four months to get internetAnd worse, it is only 10M up/down. This will suck coming from cable which was 118M down and 12M up
And the tie back to the basement is: They wanted the equipment in the basement where it would be exposed to tubing/steel/car parts attacking it.
And here we get an outdoor picture:
The clean room is at the far end.
There will be a large 14' x 44' deck over the flat area to provide some cover for my projects.
Now onto the plans:
And all these activities going on while the main house gets a mini-remodel(siding,roof)
- The clean room door will be shifted to the right and a 36" wide door will be installed.
- The clean room will get two 2'x8' racking that are stand alone.
- The clean room will get six 5' tall x 3' wide lockers to store and secure tools and parts.
- The main room with get another 2'x8' racking near the entrance
- The main room will get a sink installed after I shuffle the water heater out of the way.
- And obviously from the picture above, the outside doors are getting replaced.
Here is a picture of the lockers I will be using:
For the astute, these are the same racks used in Home Depot on end caps or other 2' narrow areas. I found out from an acquaintance he could get me cheap/free racking when HD throws it away when damaged![]()
The concern or unknown for me is what do I need to watch going down the utility sink into the septic tank![]()
Toilets aren’t trash cans!
Do you have an example of a parts washer?
One concern I have is 'open' stinky chemicals in the parts washer. I will have covered outdoor capability for one with the official shop. The basement won't have that capability![]()
Do you have a make/model of your 'small' parts washer?
If I weren't doing the mini-parts washer in the basement of my house, I'd be a little less worried about nasty flammable solvents in use. Something about the whole 'set yourself on fire while sleeping' is a bit unsettling
Originally this section had two sets of racks. I think one full set will help with organizing tools:
My problem is four fold with storage and organization:
- House hold bulk storage like paper towels, toilet paper, etc.
- Tools... larger power tools, smaller power tools, and hand tools.
- Current project parts... coil over shocks, trans cooler, turbo, etc
- Back up car parts... drive shafts, windows, factory mustang parts.
(916) 444-7225
From a year or so old estimate:
The 7'x2' up rights were $55 each.
The 8' beams were $20 each.
The 2'x4' racks were $16 each.
These were brand new. I'm sure craigslist has better pricing. The lockers were ebay scores many years ago![]()
