x
Yes, you have your dims correct.
The 2.2" difference.....waiting for the 9K winch to pull you out....or putting cable back on the drum with the 8274 because you are out already...
What size tires are you looking at installing on the 40?
How is your suspension configured?
Like Poser said about the 8274. If I were you, I would leave room for the 8274 no matter what you install initially. Cutting the frame horns too short to ever use an 8274 is not wise IMHO. My bumper is 2x4 rectangular tube, so it actually mounts to the front of the frame horns. I could have cut some off, but elected not to. If 2" of approach angle figures that big in your plans, I'm guessing you are going to wheel it pretty seriously. It would be a shame to find that you DO want an 8274 and not have a place for it without a lot of work.
GL
Sounds like a plan for a cool rig, please post pics of your progress.:beer:
Ed
GL
Ed
Ed's comment is a wise one - the ability to mount an 8274 should not be eliminated no matter what other winch is initially selected.
Also, if a winch, particularly one as tall as 8274, is mounted so low as not to block flow through the radiator wouldn't that low mounting negate the improvement in approach angle gained by shortening the frame rails?
Honk, I have mine centered in a 2x4 bumper and there is only 1 3/4" of winch
below the lower mounting hole on the Warn and 2" of bumper, so I don't think it would affect approach angle unless you mounted it below the center of the bumper, and then you would be introducing the twisty part of the equation again.
I don't think that any winch mounted above the bumper would block any less airflow than an 8274 centered. Now a low-profile planetary winch mounted that way would be even less of a problem....but then it would not be an 8274;)
Ed
I know Ed. It really depends on how determined the mounter is to avoid an imagined restriction, and I address extremes.
Along with my belief that if something can go wrong, it will rides my similar belief that if someone could do a thing very wrong, someone will.
It's not to say that John will go to an extreme which causes such a situation as I've described, in fact he sounds as though he probably won't. I would only caution against the possibilty that he or some other thread reader might do so. Because it's possible.
If long observation has brought nothing else it has brought an appreciation of the huge capacity of human beings to blow it within the scope of even their most rudimentary endeavors. :D
Honk, do you mean like a guy who has mowed his ditch with the lawn tractor a thousand times and today decided to turn it damn near over?:D
I live in a small town and the ditch is on a very busy street. Two cars stopped before I knew I was in trouble.....maybe just to watch the carnage. The '40 pulled it out handily.
Ed
8274 guys are neat, they are utterly convinced that no other winch is worth a crap..
:D
:D
Just like propane guys;)
Ed:bounce:
that why I have a diesel and a gas powered wheelin rig too???
:flipoff2:
:flipoff2:
There you go....braggin' again.:flipoff2:
Everybody has preferences and that's all they are.
Don't lose the sensa yuma.;)
Ed
8274
:D
RIGHT!!! Get a real mans winch - If it isn't a worm drive then it is just a poor investment. Next time you see a flat bed car carrier look at the winch system. It’s either a worm drive or hydraulic. A worm drive will recover vehicles all day long - long after that 8274 or planetary winch has failed. Why! Because worm drive gearing has less pressure on the gear teeth than planetary or the spur-gear drive system given the same recovery load.
