x
I'm hoping to reassemble the tailgate next week after some more powdercoating:flipoff2:
I'm curious what I use to grommet the keyed window switch.
I know at some point I saw someone had a solution but now that I need to do it, I can't seem to find it after a few searches:bang:
Howdy! IIRC, it was a plumbing washer. Head down the hardware store with your lock and get one about 1/8-1.4 bigger OD. Cut the center out bigger with a razor blade. Probably under $1. John
in the past Nat had solved this problem nicely by cutting piece of thin vacuum tubing in half and wrapping it around the opening; then slipping the lock into place.........see "The build up and progress of my Piggie!" post # 16......HTH
Lou
