As I pulled them apart, I found another interesting difference... the 34mm was bushings on the output shaft. The 38mm was split roller bearings.
The 38mm is more than likely a US spec. It is vacuum actuated which tells me it came from behind a 340?? automatic.
The 34mm is mostly unknown to me. I believe it is out of US model. It came from behind a H41 or a H42... I forget which in the pile I kept![]()
I took a minute to count some teeth and I'm only getting a partial match to the table above
For the 38mm, I counted out 24 teeth on the low speed idler. But I then counted 40 teeth on the low speed output gearThat sort of matches the 86-60 in the 2nd column. I double checked the count of 40 more than once.
For the 34mm, I counted 27 teeth on the low speed idler and also 40 teeth on the low speed output gear. I counted those out many times since 27 doesn't match anything nor does 40.
The 38mm case was provided and rebuilt by Valley Hybrid. So I 100% trust it to be unmolested/correct.
The 34mm was a package deal but appeared to be correct.
Somewhat a follow up question. If I used Advance Adapters 34mm to 38mm idler shaft 'conversion', can I install the 38mm gears into the 34mm case?
One more count on the 38mm showed I was off... it was typical 41![]()
The 34mm had typical high range spline counts: A(input) was 34 spline, B(idler) was 45 spline, and D(output) was 34 spline.
For C(idler), the count was still 27. It had an OD of about 4.5" as shown here:
The 34mm gear set more than likely came from behind a B series H41. Does the 27/40 splines mean this is a 2:1 transfercase?
Kurt, planning on running 2f, H55F, 3.73, 33” tires.
Would that combo like the 10% underdrive tcase gears ?
Yup, different gears available for split t-cases
Some info here: Cruiser Outfitters
Also stock ratios are shown on our high range/low range gear option chart too:
As you can see in the US the 34mm case was 45/25 on the idler vs 43/24 for the 38mm, non-US stuff is even different (and other ratios exist)
Kurt - Is "86-60" a typo and supposed to say "86-90"? Top green row. I think that's what you meant but just want to clarify for sure
