WTB / Needed Thread 2014
Needed..... anyone ever repaired carbon fiber on a bike?
need a pinion flange.. hard to believe i found about 4 of em in the garage.. but need this particular one for now..
http://cruiseroutfitters.com/tech_flange.html
need 1/74 to the end of course spline 78.. I can continue to tear the garage apart and will probably find one..
also need an FJ60 or FJ62 brake light switch.. Will order one when i make a parts order or i might be able to find mine.. all this stuff used to be in the garage.. who knows where it all went..
I'll replace things if I use them.. I've been known to loan stuff out so me asking isn't entirely normal..
That will complete my driveshaft project till i swap diffs out to fine spline..
Ordered a switch $2.50. It was the 2 prong variety. Flange I will need still. Ill keep looking. Thanks Rob.
Ill send u a link. Chef might have one on the shelf. Ill keep looking this weekend. No hurry its for the front. Dont need to have a front shaft installed to test drive.
I can also check spare diffs. I think all my spares are fine spline tho
Come down and check my parts anytime.
Excuse me while I whip this out....
Found my brake light switch. No flanges in my pile o parts. Well. None that met my immediate need that didnt require pulling the whole axle apart.
Thanks kelly . Had the flange I needed and was half mile from a open house we were going to.
TTT..
Eric Jobe needs a 4.7 gearset to go into a minitruck case.. prefer Marlin gearset to match what he blew up
Erik Christiansen.. Need a couple driveshaft dust covers off Fj60 or FJ62 driveshafts.. so i can finish up my driveshafts for the FJ45..Also needing a replacement double drilled fine spline pinion flange.. I loaned one of my spares out a year ago to a club member and it never made it home.. need to finish up that ARB diff..
TTT..
Erik Christiansen.. Also needing a replacement double drilled fine spline pinion flange.. I loaned one of my spares out a year ago to a club member and it never made it home.. need to finish up that ARB diff..
Working it with marlin now.
Flange is on its way. Along with perches.
Called Marlin 4 times today. Never got through.
Needed --
Anyone braze aluminum tubing? came to realization that I need to braze the A/C dryer relocation lines.
Thanks!
