Wrong grease in knuckles
Good advice. Just a head's up to correct what someone said above, which is that you can't get grease into the birf from the square plug atop the knuckle. Years ago when you were all still driving Jeeps because you didn't know any better, we wondered about that on Mud. So a day or two before I tore down for a birf repack, I put bright colored grease in through the plug to see if it would end up in the birf. It got in there in just a short amount of driving. So, yes you can lube the birf through the plug.
Well there you go. I shall not repeat this fallacy hence forth. Thanks for the education.
For what it’s worth I think I drove only one Jeep before I joined mud. I’d had quite a few LandCruisers by then.
Yes, the breather mod with fuel line and a cheap lawnmower gas filter on the tip secured up by the firewall is a great idea. Been running this way for decades and it's worthy. Whenever I grease the driveshafts - once a year or so - I put 100 squirts in the knuckles as well. Since it mostly sits, this is a ridiculous over kill maintenance for about 3000 miles, but my original shafts, and birfs run true and quiet.
...and modern moly-fortified grease is rated for high temp wheel bearing applications anyway.
And that too. Thank you, I forgot to mention that.
Probably why I decided to use it that way, plus maybe some long ago comment from the same guy you refer to?
I love the 20 posts about how to put grease in the knuckles
25 :flipoff2: It's about context and nuanced understanding. Oh...nevermind...
Zerk in place of the square plug on top of knuckle
Did Valvoline Palladium grease re-enter the market? Some time ago I couldn’t find it in Napa stores.
Chevron has a molybdenum disulfide greases. Industrial lubricant distributors will have Chevron, Mobil , ect to cover all your different greasing needs.
