Won't start, need help
Boise
I am a long time lurker and I have pulled a huge amount of information off this site but now I have an issue that I can't find the solution to and I need some help.
I have a 96 in great condition with 140k, no engine/ power train mods that has never had a problem.
I was coming off the freeway two weeks ago onto a 90 degree right turn and the truck died. I rolled to a stop and attempted to restart, it cranks well but has no check engine light when attempting to start and has never fired since it initially died. I had it towed home and I am now trouble shooting in my driveway without much luck.
The lack of a CEL leads you to the computer or power to it. It is powered from the EFI circut so I checked the fuse and the relay, both good and I also have voltage beyond them at the brass screw inside of the fuse block. I read a post that led me to the OBD outlet on the PS firewall plug B+, I have no voltage at this plug but I only saw this in one post so I am skeptical of this test. If it is a good test then it would mean that I have a short in the harness between the fuse block and the OBD outlet. I have checked all harnesses for obvious damage and moved them around with no luck.
Also, I read that there have been problems with the factory alarm system ignition interrupt. I don't use my key fob, but I have locked and unlocked the doors several times just in case that is the problem, again no luck.
I am stumped!! Any ideas?
My understanding is, if there is no CEL there will be no spark, injector pulse or fuel pressure.
How did you check your EFI relay?
How about fuseable links?
Sounds like your on the right track...
Have you checked to see if you have spark?
Need to isolate if iot is an electrical or fuel delivery problem and then go from there.
I replaced both the EFI fuse and the relay with new and I have 12v to the fuse block. I have been been chasing the lack of a CEL as an indicator that the computer did not have power, but I will go back to the basics and ensure that I have spark and fuel first. Maybe a fuel pump?
My MM happens to be next to computer so here's what it mentions for no start/no initial combustion in prioritized order for a '94. I have a '94 so some items may be slightly different. Start with spark and go from there.
1. distributor
2. ignition circuit
3. EFI main relay
4. circuit opening relay
5. vol. air flow circuit (MASS air flow on '95+ I think)
6. fuel pump
7. fuel quality
8. IAC valve
9. compression
10. valve timing
11. timing chain
12. RPM signal circuit
Just to add to your list of things to check, roll under your truck and see if the wiring harness that goes to your O2 sensors is rubbing or resting on your front propeller shaft (driveshaft). Sometimes the harness comes loose from the frame connector and wears through and blows a fuse that will allow the engine to crank but not start.
FWIW. Dan.
I found some pictures if that turns out to be the trouble. Look closely!
AAaarrrggh! Can't post them right now, PM me if you need them.
Dan.
Check to see if the High Voltage lead from the coil to the distributor is connected. The coil is located near the frame rail, left side of engine bay. This problem is rare, but has been posted on the forum before.
And yes, do check the fuse links; they can be kinked, corroded etc.
Keep the battery charged to around 12.5 volts; the ignition likes to see around 10 volts minimum to work properly.
