Wobbly 4WD
North Dakota
I’m having a couple issues:
First, when I lock my hub caps there is a little more shake than when they are unlocked. Nothing too crazy but it is noticeable. What is the likely issue?
Next, when I shift into 4WD it is a lot more shaky. What are some likely issues causing this.
Thank you for the time.
Steering wheel or whole truck in general? If truck in general i'd look at front drive shaft, start with u-joints. Then check t-case output for lateral play n same for pinion on front diff. I don't think locking hubs in should make the steering wheel shake but i've been wrong before. Good luck with chasing that down
u joints on front drive shaft?
damaged front drive shaft?
you can remove the front drive shaft and isolate the issue
