Wiring ?? HELP
Mooresville, NC -- Lake Norman
so i got my wiring harness finally installed after it caught fire and i have rebuilt it 4 times and when i try and crank it nothing...... no power to the fuse panel
i went thru the whole harness with a volt meter and replaced any burnt thru wires. the +alt wire grounded to the body and i heard a loud bang when it caught fire
i ran a wire directly to the fuse panel where the power should come in and everything works??
why dont i get any power in?? can i just run a wire directly to the fuse box from the battery -- probally not the best, or where should i connect a to get the power to the box
thanks
You should run a wire from the starter to the fuse box. The starter is connected to the battery. The wire should be connected to the same post as the battery is on the starter.
On the starter is another post there should be a wire going from there to the ignition switch and on of the wires from the ig switch should run back to the fuse box also. This will allow you to have switched and unswitched circuits. i.e. lights, flashes and such. If you need more info go to the top of the page and click on tech links. Scroll down to the electical section and click on the #2 entry and it will be the wiring diagram fo the 71.
If you want some advise on a new fuse block with spade fuses send me a PM and I will tell you what I did to mine. I had some trouble with the old fuse block.
As has been said, battery positive connects via big battery wire to the starter post. On a 71, there should be a 10 gauge white wire that goes from there to the positive post on the ammeter. Then, a white with lavender stripe wire (10 or 12 gauge) goes out from the negative post and SPLITS, one branch to the B post on the alternator, and one branch to the fuse box.
A very simple upgrade that I have learned about is to add a fusable link, which is a neat way to prevent fires (of which you are undoubtably aware). The link is standard in later FJ40s. It goes on the white wire after it leaves the starter post, and should be 14 gauge.
The way it is done on later FJ40s is a little different: the white 10 gauge wire comes off of the positive battery post rather than off of the starter post. It really doesn't matter.
You can get the stuff to make one, or buy one premade from NAPA (although you'll probably have to find it yourself, cause they won't know what you are talking about) on the electrical connector rack.
Here is one made up: the red wire on the right would be where your white 10 gauge hooks in with shrinkwrap.
Fusible link, or a Maxi-Fuse that comes with the Painless Wiring Harnesses to protect the entire harness. I've blown one of those big suckers (biggest damn fuse you'll ever see - 50 amper), and it saves the entire harness like a fusible link, only it's not a PITA to replace, just pop in another fuse, not have to take the time to rig up another fusable link. Either way, something to protect the entire harness is a must, or else clouds of smoke will billow from your hood (I speak from experience). :cheers: :beer:
The problem with regular fuses is that they are fast acting. If you have a momentary short, it blows and you have nothing: no power, no lights, nothing. Fusible links take longer to melt, but they melt before the wire burns up. They can tolerate momentary shorts and you still have power to pull off at a safe place.
I tossed my old harness for the Painless Kit. It's not to bad a job if you decide to bag the whole thing and start over. Painless does sell just the maxi-fuses with a 50 amp fuse in it. It saved my hide once already and is much easier than a fusible link in a nice little box. One note though... Buy a couple of spare 50 amp fuses. The fuse block that Painless went with is product specific to Littelfuse fuses. It won't take Buss Fuses (which are everywhere). Littelfuse fuses that big are damn near impossible to find. I couldn't find one store in Seattle that could get me one. I had to call Painless and wait for a week.
i dont have any of the guages installed at all and took out the wires to the alt since one was split wide open
thanks for all your help
