Wiring help.
Placerville, CA
I'm trying to use a 78 Steering column in a 72 cruiser. Having a problem trouble shooting the Brake and Turn lights. Anyone ever run into this before.
Pretty vague question - hard to answer. Try to give more/better detail of your problem(s).
Brake lights don't wire through the column, do they?
It's better to get both sides of the plug from the doner vehicle then both wiring diagrams then splice the harness side into the early wiring harness to the plug, some treat the hazard flasher differently, it may be part of the turn signal circuit on one but not the other, so you really need to study the diagrams and you may need a coupla of different switches to make it work.
I have both the 78 and the 72 wiring diagrams if you need them. They are also available here in the tech section. I have a cleaned up and corrected version of the 71-72 available here.
This thread might help a little- https://forum.ih8mud.com/showthread.php?t=113743
Based on info from Poser in the thread, the 72 and 78 turn signal switch function the same. You should be able to connect wires from the 78 column to your hazard switch and be set. The 72 is a single bulb system so there will be two outputs from the hazard switch that go to the rear of the cruiser, right turn/brake and left turn brake. The brake is cancelled for the respective side when the turn signal switch is on. Make sense?
I am not sure when Toyota switched, but the early (single filament for turn and brakes) and late (separate brake and turn circuits) are fundamentally incompatible, both at the circuit and turn signal switch levels.
The easy way to deal with it is use compatible parts and circuits, like using the later lamps and wiring with a later steering column. The other way to deal with is to use a 5 wire to 4 wire trailer adaptor to convert the outputs of the later column to signals compatible with the early lamp housing.
