STOP/TURN lights with EZ harness
Greetings, I was hoping someone with a similar setup (EZ harness, stock steering column, three-wire LED tail lights) could offer some advice on the wiring problem i am having.
Here is the scenario:
Originally, my FJ40 had seperate wires and lights for STOP and TURN in the rear (a red light for the STOP and MARKER lights, and an amber light for TURN).
I replaced the entire wiring harness with a generic one (EZ Wiring Mini 21) The new harness, made to be compatable with old american cars for which they are most commonly used, has one shared wire for STOP and TURN, presumably because these fuctions share the same bulb in these cars.
I also installed new tail lights (4" round LEDs common on tractor trailers). These lights have three wires, a ground for the light, a tail (marker) which lights the inner series of LEDs, and a STOP/TURN which lights the outer LEDs. These are designed to work the same way as the EZ harness as far as I can tell.
Problem number one; although the harness is new, the switches for the brake lights and turn signals are original FJ40, designed for the seperate STOP and TURN bulbs. The stock STOP switch has only one terminal for one wire going to both RIGHT and LEFT stop lights. So basically what happens is, the turn signals work fine until I connect the RIGHT and LEFT wire to the STOP switch. Then the stop switch works but the blinkers for RIGHT or LEFT cause both lights to blink at the same time (like hazards) because the two are connected at the STOP switch.
My solution was to connect diodes within both the RIGHT and LEFT STOP/TAIL wires before the STOP switch, to prevent the blinker signal from getting from the RIGHT to LEFT wire and vice versa. Installation of the diodes solved problem number one, now the turn signals work individually.
Unfortunately, this caused a second problem. The turn signals work when the brake is not depressed, but while holding the brake and blinking at the same time, there is no turn flashing. So basically whenever I hit the brakes the turn signals are left non-functional for that time.
So basically my question is, what am I missing or doing wrong? Wiring is definately not my forte. I know there are other people with this setup working (unfortunately I don't know any personally). My last resort is to simply add seperate rear blinker and be done with it, but i'd prefer to keep the single light. Any advice?
So basically my question is, what am I missing or doing wrong? Wiring is definately not my forte. Any advice?
You have done remarkably well for someone for whom wiring is not their forte.
You have basically done as well as is possible with what you have.
The basic problem is that the turn signal switch and brake light switch arrangement is fundamentally different and incompatible in the 3 wire vs 4 wire systems.
There are 3 solutions:
1. Go back to the original lamps and wiring for the '78.
2. Use a 4 wire to 3 wire trailer converter.
3. Replace the steering column or turn signal switch with either GM or early cruiser parts.
Get a hazzard switch from a single-bulb tail lamp system, ideally a 7/70-09/73, and wire it up according to a pre-74 40, and your system should work. The turn signal switch only changes power left to right and functions the same no matter what the year and the post 7/70 brake light switch is the same till the end of production and only open or closed....
:beer:
Not remarkable, but thanks... just took two weeks and many, many fuses.
Hmm, the trailer converter seems like a good idea. However, both the rear light and the harness are three wire, so I assume, as racerdave said, i would have to install such a unit under the dash. So such a converter would take the wires from the stop light switch, and the two wires from the turn signal switch behind the flasher, and magically sort the signals... perfect.
Is this the one you were going to use racer dave? - 48845 Trailer Coverter 48"
I think i'll give it a try. Thanks
:beer:
Poser, i don't understand. How is the hazard switch different in earlier years? My hazard lights work the way they are wired (I did not use all wires from the switch, only the power and individual lights. On the EZ harness the hazards are a seperate circuit, with a seperate flasher.
Also, for anyone who's done this, what circuit did you use to power the carb solenoid?
Please look at and compare the schematics from a pre-1974 and a post 1974, even with the poor drawings, it will be clear.
:beer:
Any switched 12 volt source will work.....Blower motor, wipers, ignition, radio, etc.
Good luck!
-Steve
I picked up the 48915 TAILLIGHT CONVERTER - 60". I had not thought of using a hazard switch as Poser recommended. My 66 did not have hazards. I am using a newer column with stock tail lights and that is why I decided the use the converter. My old turn signal switch functioned as a converter as the brake light switch plugged into it and the only output was brake\left turn and brake\right turn.
