Last weekend I set out to install sound deadening material on my floor. (I had done the sides and ceiling some time ago, but had been procrastinating on taking out the seats and carpet to get the floor done.)
With all the carpet out, it was the ideal time to clean up the mess of wiring I have created with years of electrical mods. It ended up taking me far longer to clean up the wiring than to install the sound deadening!!!
Also, to avoid having to snake wires under the carpet for future mods (who knows what will come next
), I routed the spares I could think of and then a few more for good measure.
Because of the number of photos, I will have to break this up into five posts below:
1) Cleaning up front driver side to passenger side wiring
2) Cleaning up wires running from auxiliary fuse box area (under passenger front seat) to rear quarter panel area
3) Spares/futures
4) Ground strip install in rear quarter panel
5) Cleaning up rear driver side to passenger side wiring
NOTE: Pictures were taken at various times during the sound deadening install, so you will see various floor coatings (OEM, dynamat extreme, ¼" foam) depending on when the pic was taken.
I've done two mods where I routed single wires from the driver side kick panel area over to the passenger side. Fished them up underneath the steering column area (through some conduit I installed for my IBS dual battery monitor, which sits on the shift console), over the tranny hump, then in and around the glove compartment. I've never been happy with this; always seemed sloppy to me.
The mods were (a) rear facing camp lights controlled by fog light switch mounted to the left of the steering wheel and (b) heated mirrors (passenger side specifically requires the wiring across the vehicle) that I tied into the rear defrost relay near the driver side kick panel. In the pictures that follow, the pink wire is for the camp lights and the red wire is for the passenger side mirror heater.
So with the carpet out it was easy to reroute these two wires (pink and red). At the same time I installed a spare/future from the driver side kick panel to the auxiliary fuse box area. This is the green wire.
), I routed the spares I could think of and then a few more for good measure.Because of the number of photos, I will have to break this up into five posts below:
3) Spares/futures
it has always bugged me that the dealer/port install ran the green wire for the trailer light connector underneath the carpet in the cargo compartment. Even though this has always bugged me, I added fuel to my own fire a few months back when I installed my LED rear facing camp lights and took the easy path and routed the driver side wires over to the passenger side along the same path.
