Winter driving (heat)
Steamboat Springs
I am thinking about getting my first 40 and it would have to be my DD. I am in western new york a.k.a cold as a mother #*%&# in the winter. how well can the heat work in one of these things? I do have a 4 year old and he would be in it sometime (bench seat) in the back....
It all depends on the individual truck you buy.
I had a 77 that would melt your skin in the coldest winter, I also had a 73 that wouldn't keep the cab warm for anything.
You might look at how well the weather stripping seals the cab of the truck, and also how well the front heater works, as well as the rear heater.
I never had a problem with the heat. Defrost was another matter. You will want to check the 2 defrost hoses under the dash and replace them if they are worn. Mine were broken and actually had a soup can duct taped into one to replace a peice that was missing. Good luck! :banana:
I'd look into those 12v seat heaters....
Not that hot is a problem around here, but 40s just don't have a whole bunch of insulation.
With a hardtop, good door seals and top seals, and a rear heater you will be REALLY warm. My softtop stays pretty warm in the winter with both heaters on. It will not happen quickly, however. My 67 hits 160 degrees in the summer, maybe 140 in the winter. Block off the radiator (cardboard) and it will heat up quicker. Plug in block heaters work very well and give immediate interior heat. You can run them into the block or in line in the radiator hose. THere are two kinds.
thanks for all the info.....i will post pics of when i get her!!!
you can also replace the rear heater with an aftermarket unit, PO ran mine for 2 years with the soft top on all winter. and it's a fair bit colder here then it is in NY.
damn i have absolutely NO weatherstripping and no rear heater and my heater duct isn't even hooked up and it burns so hot in th ecab. I could only imagine when everything is hooked up correctly
Hey Kona where in WNY are you? I live in Buffalo and just put a deposit on a 72 FJ40. I was also wondering about the quality and volume of the heat. Luckily I am generally a hot and sweaty kind of guy! :)
i live in erie pa and have driven 40s here for 35 years keep the cooling system in good shape and they work good i insulated my top with 1/2 inch foam core then reinstalled liner and its warmer and quieter good luck
Here is a good place to start.
http://www.rzeppa.org/tech/staywarm.htm
I clean heater cores with CLR full strength and you would be surprised what comes out of them. The passageways in the core are the smallest in the entire cooling system and act like a filter, trapping all the flotsam and jetsum. Very easily clogged if you flush your cooling system.
GL
Ed:beer:
Brian, the motors get pretty gunked up with grease that hardens. Take it apart and clean it, relube and go. I had to do this with two wiper motors and several rear heater blowers.
Also check to see that "High" bypasses the resistor so you are getting a full 12V.
GL
Ed
Also clean all the electrical connections from the fuse box to the blower. Might have to replace the brushes and clean up the commutator.
If your heater coil is covered with 20 years of crud it is time to pull it out and clean it. #1 cause of low air flow. #2 would be bad gaskets or couplers. You can also improve the rear fan speed by using one gauge larger wire to help prevent voltage drop.
where do we find replacement defroster hose replacement?
Depends on how much you want to spend. You can buy new from $OR ($$$) at:
http://www.sor.com/sor/cat186.tam?xax=18102&page.ctx=cat186.tam
Or buy used from:
http://www.cruiseroutfitters.com/usedparts.html
or
http://www.cruiserparts.net/parts/fj40.htm
After looking at prices, I just fixed mine with black tape over duct tape. It is just cloth over a spring. I used the duct tape to seal it up and then used black tape to wrap it. Unless you are looking right at them, you can't really tell. It probably wouldn't work for a complete resto, but Spector charges $95 a piece. Duct tape worked fine for me. However, if you don't have them, I guess fixing them wouldn't be an option.
Good luck!
:cheers:
Search for defroster hose. This has been covered many times.
Just in case you can't find it you need a hose that is slightly bigger than 2.4" which is the diameter of the metal nipple the hose slips over on the heater box. 2.5" vacuum cleaner hose should be perfect.
Note this is the diameter of the nipple for 69-73 heater boxes. I don't know what other years are.
If these are what you need, how's about $25 shipped? They aren't perfect, but very functional.
Ed
