winshield frame removal problems
Roseburg,Or
having trouble getting the screws out that hold the wind shield on every one I try to get out the head just strippes out. Have tried impact hammer didn't fase it. Only thing i know to try know is welding a nut to the head and hoping for the best
I have used a large philiips bit with a small wrench 1/4" I believe ( whatever the normal hex bit insert is) while tapping with a small hammer apply torque to the wrench . Make sure the bit is a tight fit (you should have to hammer it in ).Hope this helps.
I had same problems with mine (using penetrating oil, heat and impact driver). You will certainly have to drill some of them out when it's all said and done.
I didn't try welding a nut, however. That may do the trick with the combo of extreme heat and good leverage....
All good advice from the other posters...
My .02, The SURE way to remove them is to drill them out!
NEVER use a "screw out" or other device to remove stubborn screws/bolts. If you break them off you are "screwed" and will have to deal with harderned metal sticking out of your screw.
I had to resort to quite a bit of heat, the patient method of penetrating oil and time and hitting with a punch was a waste. Heat then drill the most stubborn of the bunch.
Replace with good stainless hardware -
Thank everybody after i posted question I relized that drilling would probably be cheapest and fastest method so probably thats what Ill do. glad to see great minds think alike
to get more grip and prevent strip out put ample quantity of valve lapping compound on your screwdriver bit...provides quite a bit of extra bite and may be the extra grip required to remove said screws.
HTH'S , Daryl
HTH'S , Daryl
#3 Phillips bit is the winner. And not all #3 Phillips are created equal. You want to find the one that matches the slots on the screw EXACTLY.
When the bite is perfect, there are only two choices. The screw will turn, or the bit will break!:eek:
Good luck.
Mark
