Here is the steel tube I could feel. First picture shows the route of the wiper harness running across the top of the glove box and up into the windshield on the far right. Second picture was taken from below the dash looking up between the body and plate in the glove box. I could feed a tube on this without much problem. One way is attach a rod to the stretched section of tube. Use the rod to start and push the tube on. Then cut the rod in the glove box so it won't be seen. At a later date if you do remove the top later you can fold the windshield down and clean it up. Just be sure to leave extra tubing.
By the way my new '78 had a hole in the hood and since I couldn't remember how this was handled on the original '78 I just plugged the hole with a hood nozzle. Maybe I'll connect it to so I can flood the dirt from the window!
