I just measured the glass from my '70. Same as yours.
The early w/s gasket is over under style meaning the glass is inline with the pinchweld. Your gasket should be 1/4"-3/16" between the edge of the frame and the edge of the glass. It looks to be correct if you are using the OE style gasket with the lockstrip.
The "rope trick" does not work with this type of install.
The later frames, wipers on bottom, uses a offset style gasket. A larger glass is required to work with it.
$125. That's seems to be their standard price for this type of install. I called a couple other shops, they were $150-250. (Obviously, the $250 shop really didn't want to do that job.)Hey Arnie (@oregon fj ), can I ask you what they charged you? I'm leaning that way also, cause I'll need to buy the lockstrip install tool.
