Windows go down but not up!?
in Jersey near Philly YO!
WTF! lol been dealing with this for a few weeks, cleaned the master switch very well with electronics cleaner a while back and all windows have worked great until a few weeks ago. The passenger front and driver's rear go down from the master switch but not up :bang: If I go to the switch at the door for that window it operates fine. Master switch is bad?? But interesting the passenger side front would go up and down at the door switch but now it doesnt go up or down. The window is down just a bit sut still I want it up!!
How can I get the window up? Hotwire it? BLAH
I had same problem on back window. I could get up barely by pulling on it. Then I bought rear widow switch from switch doctor for $12 threw it in and works fine. My old switch was worn out I guess. Worth a shot for $12 and was free shipping
When I got my truck the front passenger window wouldn't move, I pulled the regulator out and tested it manually, the motor was blown. I replaced the motor which fixed the initial problem, but I then ran into a similar issue that you are describing. The window would go down but not up when using the passenger door switch. I replaced both the master and front passenger switches with switch doctor switches...no more problems now.
Check the wiring connections in the driver's kick plate in the bottom of the A-pillar. Mine were partially unplugged and caused this type of condition.
So I took apart the master switch and the contacts were all blackened so I got the emery cloth to it. The passenger side front switch was broken inside so thats why that didn't work. I took the passenger rear switch and just swapped it so that is now functional. I just need to buy another switch and maybe the emery cloth will last a while. We shall see.
So after much research I found this on e-bay, brand new master switch from a stock of surplus OEM parts. It is specd for a 94 LC and has the lighted buttons which i want and I can still do the auto up mod. For $45 and free shipping his isn't bad. I have mine ordered and get yours soon, only 3 left!
http://www.ebay.com/itm/230947109052?_trksid=p2059210.m2749.l2649&ssPageName=STRK:MEBIDX:IT
How is this switch holding up after a few months?
The pic on the ebay listing doesn't show the lighted buttons for the switches though but yours has all windows backlit?
Oh yeh..lol forgot to update, I got it and it still wouldn't go up so I sent it back, I replaced the passenger side switch and that was the issue, then a month later the master switch wouldn't work but the window switch for that window did, so its something in the master switch, the little plastic piece under the button that moves the contacts is worn out so I gotta figure it out how to fix it. Stay tuned.
