Window rattle
Tommy Shumpert
Spring/Woodlands Texas
Which part needs to be replaced if you roll the window down and shut the door it sounds like it’s going to fall out.. Big time rattle.
The felt in the upper run of the window is good. Window nice and tight when rolled up.
Thanks
Same problem, see where this goes....
My upper runs felt good too, but you can definitely tell a huge difference in how tight they seal when rolled up once replaced
Is that ALL the parts needed to eliminate rattle?
The picture I attached earlier is for both doors. 2x 68141 and 4x 68143 on this diagram. I ended up replacing the two trim felt pieces as well (68161 and 68170 in this diagram)
Zero rattles from my door now...just everything else in the truck lol
