winch install...should the rollers be centered
in the garage
this is FJbens old piggy winch, pretty cool cable operated old school warn...
anyway.....after setting up on the 40, the winch itself looks centered but the rollers are off to the left side.
should i refab the mount(it came with the winch) and center the rollers?
cause it's not gonna look right after i build the bumper/stinger on it.
thoughts....
thanx
jim
p.s. POSER, have you got any ideas to re hook up the cables?
The spool on the 8274 is "off center" for the whole wench. Now I dont own a winch so take this with agrain of salt, but I would think you would want the spool/roller centered on the truck and fawk what the rest of it looks like. I would figure idealy you want equal pressure when pulling your self out of the crap. Granted if you use a snatch block you are going to be hooking back up to a D ring or a hook on either frame rail, but I would still suggest centering the roller.
brew8 said:
It looks centered on the spool, which is where it should be.
spool looks like it is sitting over to the driver side to me.
DOES THIS HELP?
If you still have questions, call the 4WD Center of Minnesota 1-800-328-4445. Talk to John for information on old Warn winches.... he KNOWS these things, and if there are parts available, or aftermarket pieces, he will know of them. Very smart man...
Good luck!
-Steve
Oh,
Make a front bumper, and center the fairlead on it, and weld a plate to the back side of it, and bolt the winch to it. Then you will have a significantly stronger mounting system for that winch, and be able to center your fairlead! :)
I have not ever been a big fan of mounting the winch on top of the frame using that plate. When the winch is in a hard pull, you can watch the whole thing flex and try and lever off the frame....but to each thier own.
I love the frost on that thing man.... :)
:beer:
quote usmcruiser:spool looks like it is sitting over to the driver side to me.
it is.the end of the roller sit 6" from the lh frame rail and about 10" from the rh side
thanx guys i'll have to do some cutting and re-welding on the mount.
gotta get it dropped down in the frame to ;)
I think that is a Bellview, like Bailey has. He might be of some help, too, on the cables.
Ed
Poser said:
Oh,
:beer:
YOU ARE THE MAN STEVE!!!!
i saved the pirate link.
THANX!!!!
i've got a set of instructions that warn ind. sent me.
very basic hook up for power, i think i'm gonna make my own remote switch.;)
as for the bumper, all i wanted was one that sits in between the frame rails.
would you recomend some 45 deg reinforcement for strength? (for the pull factor)
thanx
jim
edit: the pic was taken at 7 am this morn.......frost everywhere
Ed
WHO'S BAILEY? (IRISH CREME):doh:
hook me up!
the cable set up is classic, but im not to sure i'm gonna stick with it.
i will need something to lock the brake...:D
ED, did anyone contact you on your floor shifter?
you e-mailed me about you wanting to sell one.
i gave your name to a guy who pm'd me about mine...:bounce: :bounce2:
Sorry about that, Bailey is CruisinGa, or something like that. I think he had a tech article on the Bellview. He made his power in and power out.
GL
Ed
I've got the same winch on mine, the fairlead is centered, and the motor hangs off to the pass. side. I used generic parts store cables and for the power a cole hersee continuous duty solenoid mounted on the inner fender and a ford starter switch mounted on the dash, with the trigger wire to the solenoid on ignition switched power.
Mines Kinda the same winch although not exactly. I centered the rollers. Not sure it matters though, I just drilled the holes marked off of center.
Another pic....
Let me know if you need new cables, mine is set up with a plug now too :cool:
Bad, they are right, center the fairlead and have the motor offset. That also leaves room for a Sag PS box ;)
And keep it lower like wtmtnterror..
wtmtnterror said:
Another pic....
Do you have extra cables? If so I would be interested in them.
thanx guys! :beer:
i started building my bumper last night.
1/2" thick square tube from some o'le heavy bumper i had lyin around :eek: was that thing heavy!
i'll work more on it tonight and post up on monday.....i think it should be strong enough :D
