Correction:
NOT K295.
K294=F/R differential locker
K292=F/R Open Differentials
Well said! That makes sense to me. And the "viscous coupler" as I've seen it referred to, is something like a torque converter I'm guessing. I got a good look at a locking differential about a month ago when I swapped them in my rear axle. Here's the actuator motor I pulled out of it:
daily driver and our ski rig.With U.S. build qualities and a Dana frame that may rust in a dry garage.![]()
Thank you! I was 99% sure... I should have just run out and looked at my locked '95 and unlocked '97 before I posted.
A viscous coupler is never a torque converter, but more on that in a second... The viscous coupler in our center diffs can simply be thought of as being exactly the same as a viscous LSD in the rear end of a car. My '97 and '91 don't have them (the '97 had its removed by the PO and '91s didn't get them), but my '95 still has the viscous coupler... I notice absolutely zero difference between having the VC and not. Some say they notice a difference on snow roads, to which I won't argue against. But if you end up with a bad VC, it's not the end of the world to just remove it.
VC vs. TC... Basically, due to the nature of a torque converters design and operation, it can act as a gear reduction/torque multiplication device. There are many, many factors that go into this, but at full stall, you can figure roughly a 2.5:1 factor of torque multiplication and gear reduction. A viscous coupler is a fluid coupler just as the torque converter is, but it does not multiply torque or act as a gear reduction. A good example of a torque converter multiplying torque and gear ratio would be pulling away from a stop light- when you initially step on the gas, the rpms increase faster than the speed does, but if you hold your foot at partial throttle, the rpms will level off while the speed increases. That's the torque converter initially multiplying the engine torque, then "shifting" up through its range of slippage as the load decreases. It's similar to how a CVT in a snow mobile transmits power.
A viscous coupler, on the other hand, will allow some slippage (think of the viscous LSD in a rear end), but as the slippage increases, the fluid inside becomes thicker, transmitting more power through it. But only up to a point. Once you exceed roughly 30% torque bias, the VC can no longer transmit power. That's why a car with a viscous LSD will always lay two stripes, but if you put a wheel in the air, it won't move.
Bringing that back to the VC in the center diffs of our 80s... in snowy conditions where both axles have similar traction, they'll send equal torque to vote ends, but if you have one axle on ice and the other on dry pavement, the axle on ice will spin. I've experienced this with my '95... I turned down a driveway that sloped down away from the road with my back tires on pavement and my front tires on the hard packed snow in the driveway, and I had to lock my center diff to back up because the VC wasn't able to transmit enough power to the rear axle to move back up the hill.
The real reason for dorkels is really dust, not water, particularly on gas engines. Getting the intake up high can dramatically reduce the amount of dust picked up by the intake, especially if you're running a convoy in a dusty area. Meanwhile, a snorkle keeps water out, but once it reaches the distributor, you're probably going to be dead in the water. I sometimes watch Australian 4wd videos where they'll spend an entire day driving on dry, washboard dirt roads. It's amazing the amount of dust they knock off their filter elements at the end of a day.
If you look at the parts diagrams for the non-US models, you'll find a genuine Toyota snorkle. So, it's not just bro culture.
... The viscous coupler in our center diffs can simply be thought of as being exactly the same as a viscous LSD in the rear end of a car. ...
Kinda, or not so much. The VC only works with high differential in speed, so if it were to ever work, both shafts would turn at the same speed (ish) and the effect goes away. So, it's weak and brief, in other words, pretty much useless, it's biggest "benefit" is as a drive train clunk reducer.
Mandrake, thanks for the knowledge bomb.
Ok so we've all seen the video of the fj cruiser in the Middle East where the driver gets it up on two wheels and kids climb out and remove the wheels that are in the air. I wondered how the hell the raised tires wouldn’t spin but what you’re telling me is exactly that. A raised wheel wouldn’t spin.
My BFF (did I just write that?)
I haven't seen the video, but I'm guessing if they're up on two wheels and the wheels in the air aren't spinning, they probably welded the differential (or locked it if it had a locker), and removed the axle shaft from the side that was in the air. Otherwise, that would be impossible.
I'd suggest watching some videos on how differentials work. They might answer some questions you have in your head better than I've time to do so here. This oughtta get you going in the right direction: how differentials work - YouTube
A viscous LSD only works with a high speed differential as well but as it is still just a fluid coupler, its ability to transmit torque can be overcome fairly easily. It operates the same as our VCs- plates with slots in them alternating between input and output are placed close to each other in a sealed housing filled with a silicone oil and transmit power through hydrodynamic friction. As the oil heats up, it increases in viscosity which increases the units ability to transmit power, but once the fluid heats up beyond its limits, the unit slowly returns to an open or semi- open state and will no longer transmit power.
All our VC is, is a viscous limited slip differential. If it were truly a coupler, as in the only thing between the input and the output and not there to limit the speed differential between front and rear driveshafts, then we'd all be driving 2WD trucks by this point in their lives.
The VC is absolutely not a clunk reducer.
So you are saying, it has no real use?
No, I'm saying that you and inkpot have a wildly flawed understanding of what the viscous coupling does.
