WIll this pulley work for PS
Cincinnati
Pulley is from a 77 Chevy truck...Any thoughts on if this will be wide enough to except the belt. I am getting the pump from the same donor.
No, you'll end up having to switch to a narrower belt, WHICH SUCKS! Call MAF and ask them if their billet pulley will work with your pump. AFAIK they made the pulley full width.
Holy sheet...thats the $80 bling pulley! I'll have to think about that.
MO should be there soon for the parts, I sent it out the other day.
That MAF pulley is not a press on style, it is for a pump that uses a keyway only....
Have not ever used that style pump in any of the conversions I have done...
Just an FYI...
Good luck!
-Steve
Look for a pully from a Volvo. It should fit and take the wide belt.
I have never had any problem running the narrow (17/32) belts in the wide groove (22/32) cruiser pulleys (for 8 years now). They don't bottom out in the groove. The key thing is that the narrow and wide belts can't be drivign the same pulley (like the water pump) because they run at different speeds. If you have they driving the same pulley it will tear up the narrow one.
