Will it rub??
El Paso, TX
Good morning folks. I'm sure this has been brought up before but I couldn't find any info. There's a decent deal on these wheels and tires locally. I'm just curious if the bigger tires will rub. I have a stock 2000 lx470 w AHC. My tires currently are 275x70x16.This set up comes w 275x70x18. TIA and God Bless!!!!
The 18 inches are 275/65.
The 18 inch tire and wheel will stand 814.7 mm (32 inches) while the 16 inch wheel and tire will stand 791.4 mm (31.157 inches). The difference in height is 23.3 mm (0.917 inches). This makes your LX to stand about 11.65 mm (0.45 inch) more from the ground compared to your current setup..
Those should be fine. 275/70/18 is also fine on factory offset wheels. Not sure what offset those TRD wheels are, but I'm guessing very close to factory 100.
Would you happen to know if a spacer will be required?
That tire size is one above stock, i doubt it would be a problem.
