Will 3.70 thirds bolt right in...
...to my '71 Pig?
I started this idea in another thread, but need to make sure if my plan will work: 3.70's from a 60 into a '71 Pig axle housing. I suppose the big question is the axle shaft spline count, and the pinion flange I'll just deal with (can I put my '71 flange on the FJ60 pinion?).
I know others have done this, just want confirmation that I don't need to find axle shafts, too.
Better choice to post this as a separate thread; it's easier to sort tech and provide references for others this way.:)
3rd will drop straight in. Spline count the same. Plan on getting a micrometer and feeler guage set and buying a different thrust block to put on your center pin, as the button ends on the 71 axle shafts are different than the ones on the 60, so the clearance inside the 3rd will be slightly different.
Pinion flange will NOT swap. Also, pinion flanges vary in the 60s between 81-84ish and 85-87, not that it matters to your setup. I only mention it because for those contemplating this kind of swap, the driveshafts and flanges are identical for the 74-83fj40s and the 81-84FJ60s.
There are several vendors [I know that Downey is one] that offer double drilled fine spline flanges that will accomodate your driveshafts. That will be where I get mine when I do the swap in my 45.;)
Hth
Mark A.
*If* I remember correctly-
The diffs will bolt up, and your existing shafts will work. However, the pinions are different splines(and of course the driveshaft flanges are different), so your '71 flange will not slip right over the later pinions. Hopefully someone much wiser than I will post and confirm this.
*edit*...and it looks like that 'someone' already posted.
Mark A.
I have a set of FJ60 axles that I will beputting under my FJ40.
I don't know what year FJ60 they came out of.
They have circular pinion flanges
Is that the later pinion flanges?
I doubt that they have been regeared (But that would be a nice suprise!)
Apparently they varied a bit with the flanges maybe FJ vs. BJ or 40 vs. 60?
I ran into this on my FJ40. I bought some 4.11 3rds from a 1981 FJ40 to replace my 3.70 3rds from the same year. I didn't notice the flanges on the new 3rds were round and had a different bolt pattern than my original flanges (more square looking) until after I had the rear buttoned up.
Will this scenario work:
Reverse the driveshafts so the female yokes are bolted to the pinion flanges rather than the transfer case end, and get compatable female yokes that will bolt to the pinion flanges? I guess that would mean that the slip-joint on the new yokes would be the same spline as my driveshaft...
I am a little confused by the info in these posts. I bought a front axle from a 84 fj60 to use for a disc conversion. The flange on this is the square type. My 74 fj55 also has the same flange. Whats up, was something changed along the way by a PO or is this just a late 74 thing?
If I want to use the 60 diff in the rear, I have to add the thrust block on the pin, can I just pull the one off of my current diff and swap it out? I am thinking of trying this out on Sunday but I have never played around with that part of my truck yet. seems pretty simple.
That is exactly what I did on the rear of my 40 so that I could run the FJ60 CV front drive shaft on the rear. 74-80 parking brake drum, FJ60 driveshaft, stock 69-73 slipyoke and flange to the stock rear end. Been on there for about 9 years now without issue.
Best
Mark A.
Mark: Why the CV driveshaft? Does it have to do with excessive driveline angle?
