Wierd "womp womp" noise when turning
Hello everyone,
I have a 94 just picked up. Unbelievable condition not even a door ding. Owner was 77yrs old, never off road, never towed a thing only had him and his wife in it ever. 193K and most every receipt for service. Just a beautiful vehicle. Here is my first question to all of you about it when turning.
1. There is play in the steering, move of about 2 in in play back and forth with the steering wheel. before actual turning starts.
2. No other noises turning except when turning back and it is held not quite straight back, meaning the steering is just about 3-4in off center or so there is a womp, womp light sound and if you move the steering wheel that extra 2 inches or so, it will stop. The movement can be either way, left or right.
3. It is turning left or right equally and at lower speeds, such as in town, I don't recall hearing it at hyway speeds.
4. The vehicle will almost be back going straight, it is very slight not straight. So the center of the steering wheel is usually 3 and nine, this happens at 10 and 4 and 2 and 8, just a quick movement back and it stops.
5. You can not feel anything in the steering or drive. It almost sounds like a tire rub sort of sound.
6. Should I tighten the steering up any?
Lastly is there a link on all of the fluid changes, I imagine I should do everythign before 200K so I wont have to do it for awhile.
The "womp, womp" sound like Arsenio Hall may be jogging along in your blind spot, but usually it's heard in three short womps, you know, womp, womp, womp. That Arsenio, such a joker. Obviously he couldn't keep up at highway speeds, so that explains the absence of the sound on the highway.
I believe I have a video of the sound....
:steer::steer::steer::steer:
:cool::cool::cool:
fluids & flushing - all here.... coolant - trans - ps - general oil...
https://forum.ih8mud.com/threads/faq-for-80-lx450-mar-2015-added-battery-information-thread.84888/
I would definitely check the PS fluid - most use ATF - which is syrupy and cherry colored...
when my steering went katty-wompus - fluid was thin and black....
you can do "fancy" recirculation methods - I just turkey basted as much as I could - added new - bleed -
suctioned out more - replace - till it was consistent - and steering ran / runs like a charm....
bf
Man you guys are awesome...it doesn't sound or have a feeling of $$$! Also I appreciate the humor! This will be my daughters first car in 2 years. And My wife loves it so I never get to drive it.
Since I am not mech. inclined what should I be looking for that possibly can be the problem. Is the steering ok, I did read about you don't want to tighten things to much. And thank you on the power steering turkey flush, great idea I will do.
Daughter wants a roof rack and I said it has to be under 5in so prob not happening!
I agree w/ Inkpot. You will be looking for slop and movement in all of the steering linkage. Mine was missing (3) of the 4 nuts that hold the steering arm on the bottom of the right front knuckle and it allowed huge amounts of movement. I never realized there was a problem until it ALMOST fell off, which would have been catastrophic.
You also may have a tire that has a slipped belt that gives the womp noise or the steering could be low on fluid.
Congrats on your purchase and Welcome to 'Mud!! :flipoff2::flipoff2::flipoff2: (Official salute)
Yeah well, mostly the womp womp sound is mistakenly attributed to a distressed aligned wombat but when you get more aware of the subject you will know that wombat sound is more like womb womb, also know as the screeching wheel bearing, so in this case use the right cruiser semantics:
Womb, not womp:
If the sound is only at daylight and sunset that might have something to do with balancing the equator.
You definitely need to put the powerturkey in rehabilitation to get better suspension.
If I would be serious I would immediately become numb and deranged so just get a service manual to read a bit about life and the way it shakes.
If you plan to keep the truck just spend some money on safety replacement of parts with OEM only!, the steering is definitely one, brakes too, good luck, sorry I dont have 80 info/manuals.
This thread begs the question, why are you allowing your wife to drive this vehicle?
You have a potential steering/front end issue and by your own admission you do not have the mechanical aptitude to properly diagnose and/or effect repairs.
My suggestion would be to bring the vehicle to a shop or find a local member of a Land Cruiser club that can do an accurate diagnosis, but first and foremost, I would seriously consider taking it off the road.
That actually was a very good question. We are planning to have all the fluids changed and have that looked at. But here in Lincoln we do not have a exceptional Mech for these and by asking you all it helps when diagnosing the problem. I am not mech able to fix many things but do understand issues when info is given. So your help is a easy transfer to me and when it goes in next week for service I can tell the mech what you all said..minus the animal references! It also helps me brace for what needs to be done. These appear to be much more durable and HD simply engineered. Compared to our other vehicles that if a trunk opening sensor fails the car shuts down and it is towed in and costs $1000 for a $5 piece. So in summary...I learn, you all make this easy to have a failsafe LC!
